looking for more ways to make more power - Ford Powerstroke Diesel Forum
post #1 of 14 Old 03-19-2008, 12:52 PM Thread Starter
2000powerstroke109's Avatar
Send a message via AIM to 2000powerstroke109
Well I just ordered my first set of mods for my truck finally which is as follows s&b intake MSRP 304 Turbo Back SS Exhaust Stealth Monitor AKA Gauges and TW 6 Position Chip and Zoodad Mod what should I do next?
Thanks for your help in advance
Kevin
1997 F-350 CC LB 275,725 miles
Mods
Stealth Gauges
TW 6 Position Chip
Zoodad Mod
2000powerstroke109 is offline
post #2 of 14 Old 03-19-2008, 12:57 PM
Desert Shield/Storm Vet
vitalidle's Avatar
Wait till you get those mods installed you just might be content with the new found hp
2002 F-250 4x4 EC, SRW, SB
Auto 93,000 miles
DP Tuner F5
ATS Compressor and 1.0 Exhaust housing high flow back plate
Turbo Back 4" Silverline Exhaust Mbrp Muffler Delete
Isspro Trans,Pyro,Boost Triple Pod
Fumoto Oil Drain Valve
AIH Delete With Boost Fitting
vitalidle is offline
post #3 of 14 Old 03-19-2008, 01:03 PM
humboldtstrokin''s Avatar
see how that affects your turbo. You might realize that you need to mod your stock or get a new one.
humboldtstrokin' is offline
post #4 of 14 Old 03-19-2008, 02:04 PM Thread Starter
hey
Idk bout that but maybe I'm kinda looking for suggestion for the future see what I should be saving for
Mods
Stealth Gauges
TW 6 Position Chip
Zoodad Mod
post #5 of 14 Old 03-19-2008, 02:25 PM
vitalidle's Avatar
If that turns out to not be enough go pedal I would start saving for a beefed up trans, some larger injectors and a larger turbo to light the injectors. You also going to need a fuel system to provide enough fuel and maybe a dual hpop system. Everything after your current mods gets pretty pricey
Auto 93,000 miles
DP Tuner F5
post #6 of 14 Old 03-19-2008, 02:59 PM Thread Starter
Ya I Know but its the only thing I have right now that mine cuz im 19yr old im living with the rents and studying to become a diesel tech so it is gunna see all my money so price is not an object saving for it is lol
Mods
Stealth Gauges
TW 6 Position Chip
Zoodad Mod
post #7 of 14 Old 04-09-2008, 06:55 PM
Cumminskiller2007's Avatar
hpop
maybe a dumb question but wat is hpop?
Cumminskiller2007 is offline
post #8 of 14 Old 04-09-2008, 07:00 PM
Bring On The Snow
SuperDutyPSD6L's Avatar
Send a message via AIM to SuperDutyPSD6L
hpop= High pressure oil pump
Austin
2006 F-250 Crew Cab Short Bed 6.0L Fully Built 5R110
Mods:AeroTurbine 4" Turboback, SCT Custom Tunes By Elite Diesel
Leveled,Rancho RS9000XL Shocks, 35x13.50R18 ProComp Xtreme All-Terrains, Recon Smoked LED Cab & Mirror Lights
SuperDutyPSD6L is offline
post #9 of 14 Old 04-09-2008, 07:01 PM
WEWILLE's Avatar
Its the high pressure oil pump, it uses high pressure oil to run your injectors, and there are no dumb questions here, ask away!
ASE Certified Master Automotive/light duty truck Technician
ASE light diesel specialist
Ford Certified Diesel Technician
Isuzu Certified Gas/Diesel Technician
2007 F-250 PSD FX4 crew cab shortbox king ranch
2005 F-250 PSD FX4 crew cab short Box burned up
2013 Fusion 1.6L Ecoboost
2011 Ford Edge
1999 Dodge 2500 Cummins
WEWILLE is offline
post #10 of 14 Old 04-09-2008, 07:02 PM
scheidt27's Avatar
you turbo may start surging, ats housing 400, or 1.0 exhaust housing is around 300.
2002 F250
Beans Diesel Performance Tunes
All Supporting Mods
scheidt27 is offline
