Re-use new design thermostat?? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 06-09-2013, 09:19 AM Thread Starter
ScottyP5947's Avatar
Quoted: 2 Post(s)
Anyone have experience with the new one piece thermostat + gasket??? It's a pre-installed o ring so the thermostat doesn't sit metal-metal on the water pump. Can you re-use these? It sealed like a champ the first time around. It seems good but I am not a fan of re-using gaskets if you shouldn't... Can't find a one piece anywhere around me, and I won't put in the old style two part gasket. I can probably grab one from the ford dealer tomorrow morning.
Reuse or no?> What do they do at the dealer?
Scott
2000 XLT F-250 7.3 Crew Cab Auto w/Transgo shift kit
Zoodad
4" MBRP turbo back exhaust w/muffler
PHP TS chip - 65 tow/80DD/120 race
Stancor relay
Caterpillar ELC coolant
Broken-into door lock mod
6637 filter
285/75/16 Hankook ATM's
2" Rough Country add a leafs all around
In the Driveway:
2000
, chipped! (For the wife)
1995 Ford Mustang 3.8 (
2012 Dodge CCSB 2500 w/Hemi
ScottyP5947 is offline
post #2 of 6 Old 06-09-2013, 08:12 PM Thread Starter
Quoted: 2 Post(s)
I'm giving it a shot. The rubber wasn't all deformed or anything and it was less than two years old. I put on a tiny bit of black RTV on the mating surfaces and torqued to spec slowly. I have the billet aluminum flange. I'll fill and test in the morning... I'm hoping it's good, if not I can grab a new thermostat if I discover it's leaking.
SCott
Zoodad
Stancor relay
6637 filter
In the Driveway:
2000
post #3 of 6 Old 06-11-2013, 05:50 PM Thread Starter
Quoted: 2 Post(s)
Holding after a couple of days, I'm going with 'It's good' -
Talked to the dealer and yeah, they replace them each time.
Scott
Zoodad
Stancor relay
6637 filter
In the Driveway:
2000
post #4 of 6 Old 06-12-2013, 02:52 PM
blue99stroker's Avatar
Quoted: 270 Post(s)
dieselsite sells a billet housing that is awesome.
you will never ever have to replace it again.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #5 of 6 Old 06-12-2013, 07:47 PM Thread Starter
Quoted: 2 Post(s)
You know, this is exactly what I have! I still would have replaced the 'stat had I been able to get the part, but yea that housing is great. I bought new bolts last time around too. Things went together easy and I torqued them to spec so it should be all good! I would totally recommend that housing to anyone.
Scott
Zoodad
Stancor relay
6637 filter
In the Driveway:
2000
post #6 of 6 Old 06-13-2013, 09:45 AM
Quoted: 270 Post(s)
oh i didn't know you were talking about the thermostat itself.
i would go with the 203 degree thermostat from dieselsite too!
