Methanol injection - Ford Powerstroke Diesel Forum
post #1 of 12 Old 06-08-2013, 09:58 PM Thread Starter
Methanol injection
What do you guys think of meth injection ...how safe is it? And do you think a truck with straight piped exhaust and 6pos chip would make decent gains?
cmartz is offline
post #2 of 12 Old 06-10-2013, 04:21 AM
john galt's Avatar
Quoted: 1404 Post(s)
ten letters huh? BUMP
I like mead
early 04 f350 6.0 cclb lariat sr
Bulletproof oil &egr, elc, sct x3, edge CTS, afe intake, blue spring, t-500, MTW stage 2, Vivians looney, 305 x55x20 bfg at ko's, 4 inch cat back, 4"BDS fox shocks and steering stabilizer, tri pilar gauge set, coolant filter, riff raff boots, new headliner, 7 inch touch screen w/back up, new carpet, near whole new interior,
FederalOwnershipRespectfullyDeclined
john galt is online now
post #3 of 12 Old 06-10-2013, 04:51 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
Ive done a bit of shopping around for it. The snow system seems to be the cadillac of systems but the Devils Own set seems to be a nice set up at a reasonable preice.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #4 of 12 Old 06-10-2013, 05:39 AM
dannanw's Avatar
Quoted: 66 Post(s)
Garage
get the origonal...snow stage 2 er the gas miser i think they call it now. owner of the company is a total *** (is based in woodland park, colorado) but stuff they put out it top notch!
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is online now
post #5 of 12 Old 06-10-2013, 10:28 AM
rascal's Avatar
Heard nothing but good things about water/meth injection. Go for it. It is something I plan to do down the road.
Lowers EGT, improves power and MPG...I'm sold!
Good luck!
Rascal
2000 F-350 XLT ECSB ZF6 4x4
38R+WW | Adrenaline HPOP | Optima | Ravelco | Mag Hytecs | Dynatrac | EBC | Strictly Diesel | AFE | Magnaflow | ISSPRO | DieselSite
rascal is offline
post #6 of 12 Old 06-10-2013, 01:40 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
But for the price of the snow system your pay backs gonna be a long way out...
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #7 of 12 Old 06-10-2013, 02:30 PM
Quoted: 3 Post(s)
A truck straight piped and tunes isn't gonna really use much of the system. I was going to buy one, but you have to set it to come on at say 20% methanol spray at 10psi boost, then 100% at 25+ psi boost, how often do you floor it around town? I could be wrong but from what i have read its not really beneficial till you start modding the truck heavy.
2000 DRW CC 7.3
Exterior: 08 Exterior Clone, 22.5's
Engine Mods: GTP38R WW2, 5 inch exhaust,T500, 6637, TW tunes,DI Up pipes, 6.7 fuel pump fuel system.
Trans Mods: 6.0 trans cooler, JW Valve body,Billet triple disc converter.
Sound Mods: 7" flip out tv, 3-way speakers all around, 12" sub, 500 watt amp.
Misc:dieselsite coolant filter, max ac assist, BRV, IHD,gauges, CCV
Next up power rear window
campbellflage is offline
post #8 of 12 Old 06-10-2013, 03:41 PM Thread Starter
I drive highway a lot but don't really floor it around town
cmartz is offline
post #9 of 12 Old 06-11-2013, 09:09 AM
Quoted: 3 Post(s)
Are you towing? If so then u could get a meth controller that monitors egts while onthe hwy, otherwise i think you would probably benefit elsewhere
2000 DRW CC 7.3
post #10 of 12 Old 06-11-2013, 02:08 PM
I like my coolmist setup! I have a simlple system on my 1996 dodge, boost switch on and off and the 3 mpg setup on my 1999 f350 with a progressive controller . I think coolmist is good quality at a reasonable price. I got a really good deal from them because I bought both systems at the sme time. I didn't get to use the system on my f350 yet I didn't get my engine back in yet
Late 1999 f350 4x4 drw crew cab auto trans, DI 4 position chip, AFE II air filter,ftvb, 4"down pipe into 2 5" stacks, ww, ccv mode, autometer gauges , 135,000 miles. Late 1999 f250 ext cab.4x4 auto FF stage 1 injectors non EBPV pedestal, GTP 38R turbo, hydra with powerstruck tunes, gauges. 213000 miles.
Jdg5147 is offline
