Big fuel Program Wanted! - Ford Powerstroke Diesel Forum
Old 03-18-2008, 12:24 PM
I have been running the Edge evo on extreme since I got it three years ago. It was light years ahead of the Superchip I had previously. My question is, what if any programmer/porgram is the best for my set up? Should I be running custom tuning for the big a$$ lung? Can someone give me more fuel out of stock injectors than Edge? I will not consider going to bigger injectors until oil (if it does) get back to $70/barrel, I just drive it too much to go balls to the wall at this point. What is highest possible hp with stock injectors and my set up?
Thanks ahead of time.
Old 03-18-2008, 12:29 PM
A custom Tony Wildman or DP Tuner chip... as you have probably read.
call and talk to jody at DP Tuner. His tuning will be far superior to the edge, not even in the same league, or sport for that matter
Old 03-18-2008, 12:35 PM
Is it possible to max out the PMR's with stock injectors?
Give me a hp estimate with Jody's tunes.
Old 03-18-2008, 12:51 PM
Northwest Stroker
I've heard that you can only pull out an extra 90hp on stock injectors, even though your EVO says over that on extreme.
Old 03-18-2008, 01:07 PM
you wont hit 400hp with stock injectors
