Battery cables burned - Ford Powerstroke Diesel Forum
post #1 of 7 Old 06-07-2013, 09:40 PM Thread Starter
usteffenhagen's Avatar
Hey yall on my batteries it looks like my passenger side pos bat cables are burned. Same thing with my neg driver side. I'm gonna check the grounds and starter connections once it stops raining in Virginia. So am i gonna have to replace the cables that are burned? Also iv been lookin at those gold plated square lookin battery terminal connectors. Any reviews on those?
--Uriah--
2001 F350 XLT 7.3 PSD ECLB SRW automatic, 160,000(ish)
WIX 6637
4in. turbo back straight pipe 5in. tip
Zoodad
ATS turbo shroud
6pos TS chip
ISSPRO Gauges (EGT, Trans, Boost)
Foil delete
$.50 MOD
To come soon: EBPV delete, new steering gear box/ pump
usteffenhagen is offline
post #2 of 7 Old 06-09-2013, 12:45 PM
Quoted: 17 Post(s)
If by mean the gold plated square connectors with the allen wrench tightening connections. Personally I'd stay away from those. I have read that they split & break real easily. I rebuilt my cables by soldering on 3/8 eyes & using military/marine style connectors. That's tried & tested that has worked very well for me & many others.
2000 Ford Excursion Limited 4x4 Diesel
2007 Jeep Wrangler unlimited on 1 tons & with 41.5" Pitbull Rockers
TBJK is offline
post #3 of 7 Old 06-09-2013, 02:59 PM Thread Starter
Yeah I decided to just get the autocraft corrosion protection ones because I read similar reviews as you did. I also cut the cables where the corrosion started and i just gotta connect the pass side bat now... Got busy with some previously arranged engagements
--Uriah--
WIX 6637
Zoodad
ATS turbo shroud
6pos TS chip
Foil delete
$.50 MOD
post #4 of 7 Old 06-09-2013, 04:49 PM
Quoted: 17 Post(s)
That's what I did, cut back to where the corrosion was less & soldered the copper terminals on. I need to heat shrink them one of these days but real life keeps getting in the way.
TBJK is offline
post #5 of 7 Old 06-09-2013, 09:35 PM Thread Starter
Yeah I have a lot of life getting in the way especially with a week old newborn girl lol. I think I'm just going to electrical tape the exposed wires instead of heat shrink. its easier but I wonder now if the adhesive would get all up in there when it starts getting hot
--Uriah--
WIX 6637
Zoodad
ATS turbo shroud
6pos TS chip
Foil delete
$.50 MOD
post #6 of 7 Old 06-10-2013, 09:16 AM
Quoted: 17 Post(s)
In my experience 33+ by 3M holds up pretty well, I guess you could use splicing tape as well.
TBJK is offline
post #7 of 7 Old 06-10-2013, 01:50 PM Thread Starter
Thanks for the tip
--Uriah--
WIX 6637
Zoodad
ATS turbo shroud
6pos TS chip
Foil delete
$.50 MOD
