I need some backup camera help! - Ford Powerstroke Diesel Forum
post #1 of 5 Old 06-07-2013, 07:10 PM Thread Starter
027.3's Avatar
I put together a backup camera for my superduty. I used a little board cam that I had and a small project box from radio shack and put it smack in the middle of my tag (drilled a small hole through the tag and mounted from the back. Well, when I plug in the video cable to my double din dvd/radio and power it up the picture is reversed, everything on the right side of the truck shows up as the left side on the radio/monitor and vice-versa. If I reverse the video wires there's no picture. Is there any way to get the picture to show correctly? Thanks Kelly
'02 7.3 4 door 4X4 -- Leveled, WIcked wheel,4" turbo back w/ 5" tip, 6637, foil delete, zoodad mod, hutch/Harpoon mod, glow shift Egt & boost, 4- 7" 55w HIDs
027.3 is offline
post #2 of 5 Old 06-07-2013, 08:45 PM
jimhuntertx's Avatar
Quoted: 3 Post(s)
Send a message via Skype™ to jimhuntertx
Can you remove the camera from its mount? I f you can just flip it 180 and remount it.
Jim
97 F-250 2wd Extended Cab Longbox, Pyro,boost and trans temp guage, 3" down pipe,
New E4OD Trans, TS 6 chip
Banks TransComander, 4" to dual 4" Bullydog 4" Dual Exahust , DIY Tymar intake w/ K&N Filter, Shimmed FPR
jimhuntertx is offline
post #3 of 5 Old 06-08-2013, 04:25 AM Thread Starter
027.3's Avatar
Hmmm, never thought of that.... Going to give it a shot! Thanks!
027.3 is offline
post #4 of 5 Old 06-08-2013, 04:29 AM
ThomasvillePavers's Avatar
Wouldn't flipping the camera 180 just make it view upside down? you would have to be able to spin the camera on its axis if that would work?... Sounds to me like the input is being mirrored from the head unit if it has that option or possibly the wiring from the camera itself is incorrect.
-Brad
00' F350 CC DRW still pushing well past 300K: 6637, GTP38R, 5.6k mod on turn dial, superchips, trans command, Torque pro on Galxy S2 for PID monitor, OD lock, 4" straight pipe, condensor cooler w/electric fan, watersprayed intercooler, 08' taillights, 05' headlights, BD valve body kit, all door locks foiled, full LED exterior light kit, and the list is still growing.
ThomasvillePavers is offline
post #5 of 5 Old 06-09-2013, 06:12 AM
My receiver unit has a setting to reverse the image. I would look through your menus.
Ryan
2000 F250 CCSB 7.3L 4x4, Banks Ottomind computer, Banks exhaust, Banks transmission module, Banks intercooler, Banks big head actuator, Pyro, Boost, Oil Temp, Trans Temp gauges, Bank CAI, Guzzles Stancor GP Relay, Luverne whl to whl step bars, Lund Lunar Visor, 2008 tail lights and tailgate, Dynamatted, Enhanced audio system, Rough Country Add-a-Leafs in front & rear, RS7000 Shocks, Energy Suspension bushings everywhere, NUC Amsoil bypass oil filter, painted, heated, T/S mirrors, ...
Punisher29073 is offline
