Hot Shot Secret - Ford Powerstroke Diesel Forum
post #1 of 11 Old 06-06-2013, 05:09 PM Thread Starter
usteffenhagen's Avatar
Hot Shot Secret
So I was rollin around on youtube and came across a 30 sec video of Hot Shot Secret. I read some reviews but found some in favor some against. Have any of yall used this/ does it actually make a difference?
--Uriah--
2001 F350 XLT 7.3 PSD ECLB SRW automatic, 160,000(ish)
WIX 6637
4in. turbo back straight pipe 5in. tip
Zoodad
ATS turbo shroud
6pos TS chip
ISSPRO Gauges (EGT, Trans, Boost)
Foil delete
$.50 MOD
To come soon: EBPV delete, new steering gear box/ pump
usteffenhagen is offline
post #2 of 11 Old 06-06-2013, 05:29 PM
ZMANN's Avatar
Quoted: 1350 Post(s)
it was made together with ford just for the 6.0
but Ford never used it or relabeled it for their use since the 6.4 was coming( from what I remember the MFG telling us)
but with a money back guarantee I think if you have stiction it may be worth it
if not just running synthetic is all you need IMHO
We Miss you Ronnie
ZMANN is offline
post #3 of 11 Old 06-06-2013, 05:40 PM Thread Starter
Ok thanks for the tip
--Uriah--
WIX 6637
Zoodad
ATS turbo shroud
6pos TS chip
Foil delete
$.50 MOD
post #4 of 11 Old 06-06-2013, 05:53 PM
ZMANN's Avatar
I originally bought it for some injector stiction but days before it showed up I had another injector act up and they were changed under warranty so I did use the Hotshots but
just as a preventative measure
We Miss you Ronnie
ZMANN is offline
post #5 of 11 Old 06-06-2013, 07:19 PM Thread Starter
Just to be sure (im still new to the diesel community) a lot of times people misdiagnose a faulty injector because of stiction correct? and when an injector does go out is there a way to rebuild it so you don't have to spend $$$ on a new one
--Uriah--
WIX 6637
Zoodad
ATS turbo shroud
6pos TS chip
Foil delete
$.50 MOD
post #6 of 11 Old 06-06-2013, 07:23 PM
ZMANN's Avatar
there are people who say you can DIY an injector at home
I have not and not sure I would try vs picking up a ford re manufactured unit
technically stiction is a bad injector and Ford changed many out because of it
but it is something that plenty of folks have had luck getting rid of using one of the three common additives
We Miss you Ronnie
ZMANN is offline
post #7 of 11 Old 06-06-2013, 07:34 PM Thread Starter
Ok thanks. i wonder because when I am at idle in drive or park, it runs slightly rough. not sure if its just engine vibration or if there is a problem forming
--Uriah--
WIX 6637
Zoodad
ATS turbo shroud
6pos TS chip
Foil delete
$.50 MOD
post #8 of 11 Old 06-06-2013, 09:43 PM
blue99stroker's Avatar
Quoted: 247 Post(s)
Hot shots is for the 6.0 not the 7.3 so if you have A rough idle hotshots Isn't gonna fix it.
99.5 f250 7.3 4x4 260k FF 160/30, PHP Hydra, S&B CAI, 4" Exhaust, RR Billet Wheel, Autometer Gauges, Transgo, Non-Ebpv Pedestal, High Flow Outlet, 08 Tow Mirrors.
Dad-2000 7.3 4x4 110k miles, Autometer Gauges, Superchips 1705, 6637, 4" Exhaust, BD Billet Wheel, TruCool Max
blue99stroker is offline
post #9 of 11 Old 06-07-2013, 06:52 AM
Richie Rich's Avatar
Why not? Aren't the two injection systems theoretically the same? Oil actuated injectors?
2003 F250 CCSB 4x4 XLT with leather
7.3 Powerstroke with 98k miles
Ford AIS Intake
Zoodad Mod
4" Turbo Back Exhaust
Foil Delete
Rebuilt trans at 82k
Richie Rich is offline
post #10 of 11 Old 06-07-2013, 11:08 AM
Quoted: 247 Post(s)
we (7.3's) dont suffer from stiction like the 6.0's
