Question about my tire pressure - Ford Powerstroke Diesel Forum
post #1 of 4 Old 06-06-2013, 08:31 AM Thread Starter
I was wondering what I'm supposed to keep my tire pressure at during the summer/winter? I have a f250 2001 7.3 on bfg's all terrains 35x12.5x 17 and they are D range. Any ideas?
j90reaper is offline
post #2 of 4 Old 06-06-2013, 08:41 AM
Quoted: 174 Post(s)
Feedback Score: 3 reviews
You don't change the pressure with the seasons though...
Ultimately, I would use the door stickers pressures to start, after say 3000mi read the tread depth across and go up/down to compensate for uneven wear (more in the middle and lower, less and increase). My feeling is, you'll be fine-tuning for your driving conditions, loading, and driving "style" and that somebody elses recommendations may not be what You're gonna need
NoRalPh is offline
post #3 of 4 Old 06-06-2013, 08:53 AM
hansel's Avatar
Quoted: 100 Post(s)
Mine are 55psi front and 70psi rear. I rotate mine every 6,000 miles
2001 7.3L CCSRW 4X4
Airiad Intake 4" Flo-Pro Exhaust
ISSPRO EGT/Transmission
PHP Hydra
2015 Heartland Prowler
hansel is offline
post #4 of 4 Old 06-06-2013, 09:47 AM
Behavior Modificationist
AgTires4295's Avatar
Quoted: 19 Post(s)
I rotate every 5k and keep them about 10 psi under max. Always check pressure after they have cooled. I generally check mine after theyve sat overnight.
2001 7.3L
Pro Comp 6.5" Lift
Pro Comp 16x10 Alloys
35x12.5 Nitto Mud Grapplers
Sky Jacker Hydro 7000 Steering Stabilizers
K&N CAI JUNKED For A 6637
Straight Piped Dual 4"
Jasper 4R100 (Rebuilt in '05)
Tru-Cool Max
Dieselsite Coolant/Trans Filters
ISSPRO EV2 (Boost, EGT, Trans)
Centramatics
EBPV Switch
'07 Headlight Conversion
Foil Delete
Zoodad
Monitoring with Torque
AgTires4295 is offline
