What if i go over 400hp?
I know my rods will NOT hold that but if i put Billet rods and headstuds will it hold the power then. I saw someone say if i go over 400hp i would have to spend another 5k in my block
probably....but have you priced out billet rods and headstuds??
I thought 2500 for rods and bout a 1000 for headstuds? Plus the labor so i guess
the labor is gonna kill you if you have someone do it
ya id proly do it myself.
billet rods are closer to 3000 now, and headstuds are 800 iirc. Not to mention you'd better add a main girdle if you do the billet rods- that is another 1200 bucks.
BUT If you were to do forged rods for 500 bucks and headstuds for 800 you'd be able to hold 400 no problem. |
ok thanx il do more research on it
Go forged, but get then cryo'd and shot peened while they're out.
Pull the motor, pull the heads, pull the pan... the only special tool needed is a ring compressor. You don't need a rebuild kit or an overhaul kit to reinstall rods (if you're not changing pistons and rings). Now if you cylinders are scored, that's a different story. You can get forged rods for 100-200 bucks all day long. You can get them cryo'd and shot peened for a few hundred as well. You can get headstuds for 600-700 depending on if you get ARP's or H11's. For about $1500 and your time... you could have a motor capable of holding 500... Add some aftermarket rods, girdle, main studs, etc... etc... etc... and that price goes way up but your power limitation is much higher. |
wish you were my neighbor maitain.lol
I wish i was mantain nieghbor id be over there wrenching with him on his 7.3 to see how it all goes together
