2002 f-250 remote start problem - Ford Powerstroke Diesel Forum
post #1 of 7 Old 06-04-2013, 09:26 PM Thread Starter
bronco73's Avatar
I just bought a 2002 excab long bed that came with a DEI viper remote start system. The batteries were dead in the remote, replaced them and have nothing. The key fob works the power door locks and panic alarm also. None of those work either. Power door lock button in truck works fine. There is a on/off toggle switch on the bottom of the dash that is wired into the DEI system. I have tried everything that I can think of to make it work. Does anyone have this system, and have the wiring diagrams? Or any other thoughts. Thanks.
bronco73 is offline
post #2 of 7 Old 06-05-2013, 06:37 AM
need to find the alarm brain and see what model number it is...then can help with wire diagram
DONE:
EGR delete--4" turbo back exhaust
75HP tune
hotairgypsy is offline
post #3 of 7 Old 06-05-2013, 09:49 AM
dannanw's Avatar
Quoted: 64 Post(s)
Garage
not much else we can do without more info
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #4 of 7 Old 06-05-2013, 02:34 PM Thread Starter
bronco73's Avatar
I did some more digging into the truck and started taking the zip ties apart to trace wires. I found two black boxes about 3-1/2"x 2-1/2" and about 1" thick. One of the boxes had two harnesses going into it, one was unplugged. I plugged it in and now my power door locks work with the key fob. The only numbers I found were on that box on the back. I think this is what they are.
FCC ND EZS249563
Also after i plugged it in the panic button kinda works. the lights flash and the door dinger work but no horn.
Thanks.
bronco73 is offline
post #5 of 7 Old 06-05-2013, 02:35 PM Thread Starter
bronco73's Avatar
and no remote start yet. the box under the dash just clicks once.
bronco73 is offline
post #6 of 7 Old 06-05-2013, 03:37 PM Thread Starter
bronco73's Avatar
i just fixed it. helps if the doors are closed before you try the remote start. lol. thanks guys.
bronco73 is offline
post #7 of 7 Old 06-07-2013, 06:53 AM
thas funny!!! good job techman!!! ya did great....now go get ya self a beer...
DONE:
75HP tune
