engaging 4x4 high and low - Ford Powerstroke Diesel Forum
post #1 of 13 Old 03-15-2008, 11:15 AM Thread Starter
slowcoupe's Avatar
Quoted: 11 Post(s)
ok i have a quick question for you guys. i did a search and came up with some good info about the 4x4 in these trucks but noting solid on what i need. I looked at a truck last night. I took it for a drive and on the fly engaged 4x4. Everything came on fast could feel the front wheels pulling. Came to a stop. put in in neutral pushed in the brake engaged 4 low. it made a clunk? i assume that is the servo on these trucks? ran good in 4 low. took out of 4x4 and i brought it back to the place. i came to a stop and again went to put into 4x4. it would not engage 4x4 (high or low) at a stop. does the truck have to be moving to engage 4x4 high or low?
slowcoupe is offline
post #2 of 13 Old 03-15-2008, 11:32 AM
Other vehicle is an F250
Hank's Avatar
4x4 high on the fly
4x4 low must be in neutral with foot on brake
2001 F250 Lariat Crewcab, Automatic, 4X4
(Late '99 Regular Cab Work Truck)
6.5" Pro Comp Lift ~ Traction Bars ~ Son-Built Sliders ~ 16" Pro Comp Xtreme Wheels with 35" BFG TA KM2s
4" Banks Exh.-Power Elbow ~ Wicked Wheel ~ DIY AMSOIL EaAU4090 Intake ~ PHP 6 Pos Chip ~ LowDown LED Upgrade
Stage 1 Injectors ~ HankDaddy
Mod. ~ BUILT TRANNY! 352 HP Shootin' for 375!
CAROLINA POWERSTROKE ASSOCIATION
Hank is offline
post #3 of 13 Old 03-15-2008, 11:36 AM Thread Starter
slowcoupe's Avatar
Quoted: 11 Post(s)
yes i did both of those. but will 4x4 high engage at a stop with the truck in drive. cause this one didnt. but it did engage while driving
post #4 of 13 Old 03-15-2008, 11:39 AM
Hank's Avatar
I'll go check....be right back......
Hank is offline
post #5 of 13 Old 03-15-2008, 11:42 AM
Hank's Avatar
Yep.....Light came on...seems to be in 4x4 hi. Raining like crazy here!
Hank is offline
post #6 of 13 Old 03-15-2008, 11:55 AM Thread Starter
slowcoupe's Avatar
Quoted: 11 Post(s)
ok cool thanks alot. thats what i thought. its a lady that owns the truck and i asked about the 4x4 and she had he husband come check it out. the guy told me sometimes you have to reverse or drive a little forward before it will engage. my dads bronco will engage right away when you press the 4x4 button in park. didnt think something was right.
post #7 of 13 Old 03-15-2008, 05:35 PM
Hank's Avatar
Mine is a 2001 with Auto/Lock hubs. Not sure if other years are different. Saw your profile....my 21 year old son is a career fire fighter! Thanks to both of you. Take care.
Hank is offline
post #8 of 13 Old 03-22-2008, 02:52 AM Thread Starter
slowcoupe's Avatar
Quoted: 11 Post(s)
ok i called a few ford dealerships in town and spoke with some techs. they said the truck should show engaged in 4x4 in park when the truck and the key is in accessory.when running in drive neutral or reverse. it engages into 4 high while driving and also engages into 4 low when i come to a stop put into neutral and foot on brake. what would cause it to not go into 4 high or low while stopped. .i really like the truck and am just trying to figure out if this will be an easy fix.
post #9 of 13 Old 03-22-2008, 10:43 AM
Thats why I go with the manual engage, takes all the guess work out.
BYetter is offline
post #10 of 13 Old 03-22-2008, 10:53 AM Thread Starter
slowcoupe's Avatar
Quoted: 11 Post(s)
haha thanks man but thats not helping me any. i have done alot of reading and have read it can range from vaccum seals on the hubs to a bad connection to the motor. What are the most common problems seen. im assuming its gotta be vaccum since it engages perfectly when driving.
