Send me to a broke window thread? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 06-03-2013, 06:20 PM Thread Starter
Hi all, I am searching for a thread on window motors. My 2000 F250 passenger side window goes down, but not up. It is currently in my carport with the window stuck down. I'm leaving town for a trip in a couple days and want to get this thing rolled back up before leaving. Any tips/threads/links/schematics on the window and motor are greatly appreciated. Thanks!
zealant is offline
post #2 of 8 Old 06-03-2013, 06:26 PM
ZMANN's Avatar
Quoted: 1469 Post(s)
it is just current reversing so have you bypassed your switch and powered it directly to rule out the switch ??
We Miss you Ronnie
ZMANN is offline
post #3 of 8 Old 06-03-2013, 06:43 PM Thread Starter
Hi Zmann, thanks for the reply. I have not, I'm not sure how to do that actually. Happen to have directions on doing so?
zealant is offline
post #4 of 8 Old 06-03-2013, 06:50 PM
goats's Avatar
Quoted: 2 Post(s)
Hold the up button and hit the door panel with your hand just right of the speaker at the same time.
goats is offline
post #5 of 8 Old 06-03-2013, 06:54 PM
ZMANN's Avatar
or try that !
LOL
you would have to ull the door panel and access the motor
then run a power lead and ground to the motor leads
revers them for up and down
you could do it at the switch but I don't know how to tell you that procedure
We Miss you Ronnie
ZMANN is offline
post #6 of 8 Old 06-03-2013, 06:59 PM Thread Starter
Sounds good. I did try pounding the door out of frustration, no luck lol. Good idea though Goats. Good idea with the switch Zmann, I will try that out in the morning and see what happens. Will keep you posted. Thanks!
zealant is offline
post #7 of 8 Old 06-03-2013, 07:17 PM
schlutzer's Avatar
Quoted: 18 Post(s)
you have to pound the door while holding the button or it wont work lol.
my old truck would die every once in a while... slam the door with the button held worked everytime
schlutzer is offline
post #8 of 8 Old 06-03-2013, 07:31 PM
nohsp4u's Avatar
I would
1) remove door panel
2) disconnect the window motor connector
3) Using a portable 12v battery source, jump box etc, connect the the motor. if it goes up, reverse the connection, if it goes down, test you switch with an ohm meter. If switch is bad, replace. If switch is good, test all connectors and then continue back looking for short.
Most likely a bad switch.
I used this method to power the motor in a junk yard to pull glass. Worked great.
1997 F-350 XLT Lariat Crewcab long box 4x4. Oxford white with an ugly green. 133xxx miles. Hide away goose neck, banks turbo, exhaust, inner cooler, intake filter and gauges.
nohsp4u is offline
