Do I need to turn off my overdrive towing my boat. - Ford Powerstroke Diesel Forum
post #1 of 8 Old 06-03-2013, 05:21 PM Thread Starter
kystanger's Avatar
I have a 21 foot ski boat and the boat and trailer weight around 3500# should I turn my overdrive off when towing it. I always turn it off when pulling heavy loads but didn't know if my boat was heavy enough to need to turn it off or not.
2008 f350 4x4 Stock
(SOLD)2001 f250 4x4
319,000 miles and counting.
6637 intake, 4 inch MBRP exhaust,gauges,203 degree therostat, leveling kit, transgo tugger kit, front and rear mag-hytec diff covers, more to come.
kystanger is offline
post #2 of 8 Old 06-03-2013, 05:36 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
I would guess probably not but if your truck seems to always be searchin for the right gear go ahead and do the tranny a favor and hit the tow/haul button
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 8 Old 06-03-2013, 07:16 PM
schlutzer's Avatar
Quoted: 18 Post(s)
I'm lifted on 37's and towed my old ranger + full trailor... probably about 6000lbs total and left O/d on. It was fine unless I had to slow down on a hill ( I was on a major highway) you should be just fine won't even notice it back there
schlutzer is offline
post #4 of 8 Old 06-04-2013, 05:02 AM
goats's Avatar
Quoted: 2 Post(s)
You really shouldn't really feel it behind you,cause I don't feel my ski boat.
goats is offline
post #5 of 8 Old 06-04-2013, 05:48 AM Thread Starter
kystanger's Avatar
Thanks guys, I didnt think it would be a problem to pull it with overdrive on. Just wanted some opinions, Ive only had this truck about 6 months and it has a fairly new trans in it so I didnt want to screw anything up. My last truck was a 6.0 and I pulled my enclosed trailer with my mustang in it and it got much better fuel mileage with overdrive on than with it off so I was hoping to leave it in OD and save some fuel. Thanks
2008 f350 4x4 Stock
(SOLD)2001 f250 4x4
post #6 of 8 Old 06-04-2013, 06:16 AM
2000-7.3L's Avatar
Feedback Score: 10 reviews
These trucks are made for towing! I tow a 10,000 lbs concrete trailer and have never used O/D button while towing! Never had a problem and tows like a dream!
2000-7.3L is offline
post #7 of 8 Old 06-04-2013, 08:10 PM
The overdrive button isn't something you say, "turn it off when pulling BLANK pounds" Its something you feel and decide on based on the way your truck feels/sounds.
For example, when pulling up a steep hill, your truck may still be in overdrive based on speed you are going. Your engine will be lugged way down though. This is what you don't want, It puts alot of strain on your transmission. Clicking it out of OD when your engine RPMs are very low causes you to jump back to 4th which increases your RPMs. You will be able to cruise up the hill with higher speed, and more power, all while extending the life of your transmission.
Sometimes, I even use it when not towing. Sometimes the trans doesn't kick out of OD on its own on a hill, so I do it manually with the OD button. When empty or towing, after the hill, when you are back on cruising again, kick it back into OD and you can pickup some more speed at a lower RPM
99' F-350 CCLB 92,100 miles ▬ 05 headlights 4" exhaust 6637 Gauges F650 dash blue LED interior HID Headlights & offroad lights 20" LED lightbar PHP Hydra 08 Taillights
97' F-450 Powerstroke 4x4
03' Peterbilt 379 650+ CAT
02' Cummins 3500 flatbed
peter379 is offline
post #8 of 8 Old 06-04-2013, 09:33 PM
'01SilverBullet's Avatar
Quoted: 4 Post(s)
I go off how hard the truck is pulling and how fast I'm going.
2001 F250, 7.3, Automatic, 4x4, 33's, Leveled, Cobra 29 CB Radio, Dual Firestick Whips, Pioneer Head Unit, Riffraff 6637 Intake Kit, 4" turbo-back straight pipe, Dual Alternator Upper Radiator Hose, AutoMeter Boost, Pyro, Trans Temp, Delta Toolbox, Gooseneck Hitch and a heavy right footed driver...
Wishlist: 160cc single shots, GT38r, BTS, SRP 1.1
REAL TRUCKS DON'T NEED SPARKPLUGS!!
Lord, please take care of this drivin' fool...
'01SilverBullet is offline
