Rear differential question - Ford Powerstroke Diesel Forum
post #1 of 9 Old 06-03-2013, 02:53 PM Thread Starter
Ford Cowboy's Avatar
Quoted: 5 Post(s)
Gonna change front and rear diff fluids this weekend. Got the build sheet for my truck (2000 f350 7.3) this afternoon and it states that I have a 3.73 non-limited slip rear end. Now, when I pop the cover off is there a way to tell just by looking wether or not it is indeed a non limited slip? I was really hopin it was a LSD. My manual says to use 75w-140 for rear and 75w-90 for front. I found some royal purple gear oil with friction reducer already mixed in. What do y'all think of royal purple? Thanks for any help
cummin is the mess left behind by strokin!!
2000 7.3l f350 4x4 cclb psd. 4r100 trans.Ranchhand everything! 6637 intake, zoodad mod, custom big rig runnin lights, ccv mod, RR boots and plenum inserts, foil delete, EV2 gauges, edge cts, tuff country 2.5" leveling kit, X codes, 315/75r16 coopers, 08 mirrors, 6.0 trans cooler, tgc dual steering stabilizer, fabtech adj. trac bar, mbrp 5" turbo back straight pipe with 8" tip, php 6pos, ssbc brakes, ebpv delete, cat elc 100,xxx
Ford Cowboy is offline
post #2 of 9 Old 06-03-2013, 03:02 PM
Quoted: 17 Post(s)
Feedback Score: 3 reviews
yes, you can tell a difference by looking at them but i am not good enough at typing to tell you the difference. take a pic and post it up and somebody on here should be able to tell you. check your rear cover as they are bad about rusting through and leaking. i sanded and painted mine, alot of people go to the 08+ style. i feel that royal purple is overpriced and overrated but that is my opinion. i would suggest schaeffers or amsoil.
2000 F250 XcabSB, 4x4, 4" strait pipe, DIY intake, FRx, BDP tunes, WW2, 6.0 cooler, BTS VB, gauges, 55w digital projector HIDs
gomer pyle is offline
post #3 of 9 Old 06-03-2013, 04:14 PM Thread Starter
Quoted: 5 Post(s)
I'll try to post some pics. If anybody has any pics of the different differentials and can post em that would be sweet. I got to thinkin I know the manual says to use 75w-90 in the front, but why couldn't you use 75w-140??
post #4 of 9 Old 06-03-2013, 04:29 PM
ZMANN's Avatar
Quoted: 1911 Post(s)
this may help
you can spy the clutches on the pass side
http://www.fourdoorbronco.com/board/...c-lock-rebuild
We Miss you Ronnie
6.0 flush pdf
ZMANN is offline
post #5 of 9 Old 06-03-2013, 05:16 PM
Rp is junk from my experience. I either use amsoil or lucas for my diffs. Especially in the race car we use lucas diff fluid.
99.5 F350 DRW CC 4x2 53k on the clock 7.3 6637 intake mod. Hand made 4" exhaust. 4.10 gear.
92 Mustang lx 362ci N/A 830hp. Ultra street & X275 car
calypso50kid is offline
post #6 of 9 Old 06-03-2013, 05:32 PM
juniorssrollin's Avatar
Quoted: 2 Post(s)
Amsoil in both my diffs and transfer case..
Sent from AutoGuide.com App
2005 F350 CCLB FX4
juniorssrollin is offline
post #7 of 9 Old 06-03-2013, 06:09 PM Thread Starter
Quoted: 5 Post(s)
Cool I'll look into amsoil. I pulled some numbers off of the tag that hangs off the back of the differential. Maybe someone can decode it.
S-406 F
73 10 5 9M10
I just have a really hard time believing that there is no ls. The old rancher I bought it from (died last summer) had this truck custom built with all the options available for the year 2000. He was real particular in what he wanted and it just doesn't make sense that he would not have optted for a lsd. I'm gonna rip it apart this weekend and try to post some pics. FYI I looked for an axle code on the driver side door post and the axle code slot is blank. I was scratchin my head on that one
post #8 of 9 Old 06-19-2013, 08:09 AM
jacobm24's Avatar
I used rp when I did my diff fluid with the fr mixed in. About a month later I ended up buying a bottle of fr from the dealership and putting it in there until it felt right on turns.
2000 f250 7.3 w/ 103k miles
4" MBRP turbo back exhaust
DIY Intake with AFE big boost filter
Autometer Cobalt gauges (trans, boost,pyro)
PHP Phoenix stock, 40ht,80dd,120race
Wicked Wheel
Harpoon Mod
203* thermostat
Dieselsite coolant filter
Dieselsite IC Boots
Fightin' Texas Aggie Class of 2013!
Petroleum Engineering
jacobm24 is offline
post #9 of 9 Old 12-19-2013, 07:38 AM
S406F is an open differential
Fr. Frank is offline
