Injectors..... need advice/build thread??? - Ford Powerstroke Diesel Forum
post #1 of 75 Old 06-02-2013, 08:52 PM Thread Starter
jse51599's Avatar
I am in the process of doing the standard maintenance items on my 99. First, I should state that I have way more time than money, so it'll be awhile before I get completed. That said, I am doing this because my transmission case cracked which led me to pull the trans. This then led to the idea of replacing the up pipes of course, and has steadily snowballed from there..... So, I've decided on a laundry list of things to replace including the glow plugs, uvch, and valve cover gaskets. This finally brings me to my reason for the post..... Sorry I have around 168,000 miles on the motor with no issues as far as how it runs. That being said, should I consider replacing the injectors? By the way, I am pulling the motor out to fix the rear main seal and replace the oil pan. Any advice would be great, and I'll try to update with pics as I go.
6637, Diamond Eye Turbo Back, Riffraff Billet Intake Plenums and Intercooler Boots, WW2, Deleted EBPV
305 70 16 Toyo A/T IIs
Jim
jse51599 is offline
post #2 of 75 Old 06-02-2013, 10:02 PM
Joel's Avatar
Quoted: 10 Post(s)
They shouldn't need replacing
Are you looking to go bigger like stage 1 or 2 or something?
I sure as heck wouldn't replace them just for the fun of it unless you're just lookin to go faster.
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #3 of 75 Old 06-02-2013, 10:07 PM Thread Starter
jse51599's Avatar
No, not looking to go bigger. I wasn't sure if the next size injector would be be better to go with.
Jim
jse51599 is offline
post #4 of 75 Old 06-02-2013, 10:40 PM
Quoted: 725 Post(s)
Is your oil pan that bad? Chances are your rear main seal is not bad. Its rare they leak.
Corey@CNCFAB is offline
post #5 of 75 Old 06-03-2013, 02:10 AM
Codum's Avatar
I agree with hucorey above, I doubt your rear main seal is leaking. I would look for an oil leak on top of the motor, hpop related or ebpv etc. Any oil leak on top of the motor will drain out the back of the valley thru a hole and look just like a rear main seal leak. I also agree that your injectors should be fine, I just replaced my stock ones at 458,000, although I should have replaced them around 350k-400k as I really started looseing power around 400k.
2002 F250 CCSB Lariet 7.3 Auto
2" helper springs 285/75R16 Toyo M/T
80 gallon fuel tank in bed
DIY 6637
Warn Premium Hubs
Ford Transmission @ 407,425 miles 3/24/12
Full Force Injectors
Avic X930BT w/ backup camera
"We Farm for Ducks"
As of 6/11/16 605,552 miles
2005 Excursion Eddie Bauer 4X4 6.0
Stock 225k miles
Codum is offline
post #6 of 75 Old 06-03-2013, 03:25 AM Thread Starter
jse51599's Avatar
There isn't any oil in the valley and there's none going down the back of the engine. If I get a chance this evening, I'll get a pic of the back of the motor and the oil pan. It's not a huge leak, but I figured I'd fix it now while it's easy to get to...
Jim
jse51599 is offline
post #7 of 75 Old 06-03-2013, 05:16 AM
Quoted: 725 Post(s)
Mine also leaks at the back and its my oil pan at the very rear corner where the starter bolts up at. Its not a normal spot like a turbo pedestal O-ring, but not rare either.
Remove your flywheel inspection cover, start it up, then get under your truck to watch.
post #8 of 75 Old 06-03-2013, 05:20 AM Thread Starter
jse51599's Avatar
Well, the only problem is that the motor mounts are the only thing holding my engine in place right now...
Jim
jse51599 is offline
post #9 of 75 Old 06-03-2013, 12:43 PM
Quoted: 725 Post(s)
Oh yeah. Lol. :p
post #10 of 75 Old 06-03-2013, 12:59 PM
wingfooted's Avatar
Not a bad idea to replace the injector o rings while you are in there working on the glow plugs and harnesses. Cheap insurance.
2000 Ford 7.3 powerstroke/6 speed ZF6/4WD/50 Gallon transfer flow auxiliary
2009 Ford F-150
1998 Ford Mustang GT
1978 Toyota BJ40 diesel, 12V, LFD
2008 Husqvarna TE510
1974 Honda 250 XL250 K0
wingfooted is offline
