Power mirror trouble shooting - Ford Powerstroke Diesel Forum
post #1 of 12 Old 06-02-2013, 01:07 PM Thread Starter
Wyofordpower's Avatar
Quoted: 2 Post(s)
I have a late 99 f250 and the power mirrors have stopped working. I checked the fuse, #4 in the passenger compartment and it's just fine. Popped off the switch panel on the door and all connections look and feel good. I'm gonna check the ground wire for the switch next but in the meantime does anyone have anything else that they would suggest looking for or checking?
Wyofordpower is offline
post #2 of 12 Old 06-05-2013, 06:07 PM
Take the adjusting switch apart and clean the contacts. All will work again.
arcticatdan is offline
post #3 of 12 Old 06-08-2013, 05:12 PM Thread Starter
Quoted: 2 Post(s)
Took the switch all apart and cleaned all the contacts, still not working.
On another note, the 7.3's did not have power extending mirrors, correct?
Mine are stuck in the fully out position and refuse to go in by hand.
post #4 of 12 Old 06-08-2013, 05:54 PM
Mine didn't work when I bought my truck last September. Replaced the switch (only like $20) and worked fine!
01 F350 CCSB 4x4
Leveled
AIS
4" mbrp straight pipe
Va7.3L is offline
post #5 of 12 Old 06-08-2013, 06:11 PM Thread Starter
Quoted: 2 Post(s)
Know if there is a way to bypass the switch to see if it is the problem?
The mirrors were working intermittently when I bought the truck in November but they have not been working since December.
post #6 of 12 Old 06-08-2013, 06:32 PM
good luck man, the phantom electrical issues in my truck have finally caused me to quit caring about interior lights and other stuff like that.
My mirrors are kinda sticky, but the switch is my problem there too. I think you're on the right track by tracing the ground wire, if it's not the switch most electrical issues on fords are from bad grounds.
wyndsurfr is offline
post #7 of 12 Old 06-08-2013, 07:01 PM
Quoted: 725 Post(s)
Do continuity checks on the wires with a multimeter.
Corey@CNCFAB is online now
post #8 of 12 Old 06-08-2013, 08:21 PM
Honestly, I did no testing. A buddy of mine with an 03 7.3 had the same problem and he changed the switch and it worked so I did the same. I may have just got lucky.
01 F350 CCSB 4x4
Leveled
AIS
Va7.3L is offline
post #9 of 12 Old 06-19-2013, 09:00 AM
jacobm24's Avatar
I had to change the switch on mine also. $25 at the dealership. Works like a champ now!
2000 f250 7.3 w/ 103k miles
4" MBRP turbo back exhaust
DIY Intake with AFE big boost filter
Autometer Cobalt gauges (trans, boost,pyro)
PHP Phoenix stock, 40ht,80dd,120race
Wicked Wheel
Harpoon Mod
203* thermostat
Dieselsite coolant filter
Dieselsite IC Boots
Fightin' Texas Aggie Class of 2013!
Petroleum Engineering
jacobm24 is offline
post #10 of 12 Old 06-19-2013, 07:58 PM
Just got a switch for $14 from eBay and my mirrors work now :-)
2000 f250
diy intake
4"straight pipe
ccv dumped outside
paulgl26 is offline
