Fluid dampners - Ford Powerstroke Diesel Forum
post #1 of 3 Old 06-02-2013, 09:15 AM Thread Starter
russtwentyfour's Avatar
Fluid dampners
I'm am in the process of gathering parts for some maintenance that needs to be done on my e99. Water pump, melling oil pump, hoses and belt. Have this annoying leak at the LPOP and a small dribble every now and then from water pump. Question is, are the fluid dampeners better than the OEM rubber ones? I figure like anything else once I remove the dampener it will have a groove cut in it from the front seal so why not replace with something better since I have to replace anyway.
E99 F350 Ext. cab Long bed, single wheel 2x4
Riff Raff 6637 intake, FRX and HPX,
Dieselsite boostfooler, factory tech valvebody, filter system,
Local custom trans build - BTS in near future,
Derale cooling pan and trans cooler,
Mbrp 4" turbo back
Ts 6 pos chip - TW tunes coming soon,
Guzzles hutch and harpoon mod with lift pump and racor filters
Ww2
Blank pedestal with moded exhaust port
Afe rear end cover
Callahan drilled and slotted rotors front and rear
russtwentyfour is offline
post #2 of 3 Old 06-02-2013, 11:16 AM
I have used a fluid dampner only twice. Once on a dodge cummins with a few mods and another time on a 4.0 chrysler inline 6 in a 2000 jeep cherokee bored and stroked to a 4.7. It definitely made a difference to me in the overall "smoothness" of the engines. I don't remember seeing any major performance gains but at idle and low range rpms I could really tell a difference.
Keep in mind though inline 6's are more prone to crankshaft distortion than a V-8 and I have no experience running it on a v engine. So i couldn't tell you what it would feel like on your truck.
2001 CCLB DRW 4X4, 6spd, TW 6 Pos, 6637, 4" turbo back, 203* stat, Driven Diesel Reg Return, HPX, CCV mod, 33" all terrains
Project Luxury Work Truck
SSonnier is offline
post #3 of 3 Old 06-02-2013, 05:07 PM
ACC
Don't worry about a groove here is a replaceable race on the damper where the seal rides on it.
Tom
95 F250XL PSD SuperCab, BTS E4OD with a 6.0 31 row cooler, TS 6 position with Gearhead Tunes, Downpipe, Vegistroke V3, Tymar Intake, Autometer gauges, Gutted EBPV, Tymar Coolant Filter, Crystal Headlights, AC Mod, OilGuard Bypass, Stage 1's, Adrenaline HPOP, 370k and still Smokin.
Early 99 XLT SuperCab Auto, 4" Exhaust, DIY Tymar, Autometer Gauges, PMT2 ECU
ACC is offline
