Transmission Temperature - Ford Powerstroke Diesel Forum
post #1 of 37 Old 06-01-2013, 01:05 PM Thread Starter
I did some reading using the search function but couldn't find exactly what I was looking for.
I noticed today while driving my transmission temperature got to 185 degrees. It was about 85 outside.
My question is...is 100 degrees over ambient acceptable? I was not driving hard and had no weight in the truck. Seemed like it might be a little high considering nothing was being towed.
Pipewrench is offline
post #2 of 37 Old 06-01-2013, 01:07 PM
Quoted: 3 Post(s)
time to look into a 6.0 trans cooler.
2000 DRW CC 7.3
Exterior: 08 Exterior Clone, 22.5's
Engine Mods: GTP38R WW2, 5 inch exhaust,T500, 6637, TW tunes,DI Up pipes, 6.7 fuel pump fuel system.
Trans Mods: 6.0 trans cooler, JW Valve body,Billet triple disc converter.
Sound Mods: 7" flip out tv, 3-way speakers all around, 12" sub, 500 watt amp.
Misc:dieselsite coolant filter, max ac assist, BRV, IHD,gauges, CCV
Next up power rear window
campbellflage is offline
post #3 of 37 Old 06-01-2013, 01:19 PM Thread Starter
So 100 degrees over ambient is too high? At what temperature could failure occur?
What should it be in an ideal scenario?
I'll look into the 6.0 cooler.
post #4 of 37 Old 06-01-2013, 02:05 PM
Quoted: 3 Post(s)
Your not crazy high, below 200 is fine, above that and the fluid starts to break down fast and the trans can be damaged. Im live in FL, unloaded even in the hot summer months with the 31 row 6.0 trans cooler I rarely see over 150.
2000 DRW CC 7.3
post #5 of 37 Old 06-01-2013, 03:15 PM
Justin@DP-Tuner's Avatar
Quoted: 48 Post(s)
100* over ambient is okay/normal, but most people see that when they are towing something. You do not really want to go over 220* at all.
I would invest in a bigger cooler as well.
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
post #6 of 37 Old 06-01-2013, 03:47 PM
jesilvas's Avatar
Quoted: 2 Post(s)
I never run that high.
Were you on hwy or city? TC locked or unlocked?
4R100, 2wd
330,000 + miles
jesilvas is offline
post #7 of 37 Old 06-01-2013, 06:24 PM
Quoted: 13 Post(s)
Feedback Score: 3 reviews
i would do a 6.0 cooler and change out the bypass tube
2000 F250 XcabSB, 4x4, 4" strait pipe, DIY intake, FRx, BDP tunes, WW2, 6.0 cooler, BTS VB, gauges, 55w digital projector HIDs
gomer pyle is offline
post #8 of 37 Old 06-01-2013, 06:42 PM
2013F250Tank's Avatar
I have a 6.7 and its norm is 196* hwy 203* Not loaded
13 F250 Lariat CC SB 3.31 EL axle w/SPE full lock module, Ultimate Interior,
H&S Big Single 64mm NON VGT Turbo Kit, Cast manifolds, NON Cobra downpipe, Mini MAxx w/H&S stock fuel tune
Down Pipe back 304T 4" Diamond Eye, AFE stage II intake, front 4 link,
Road Armor bumpers front/rear. N Fab nerf steps. 20" American Force w/Trxus 33",
Dura flaps, Air Lift rear bags, 34k+ miles, Stage 3 traction block bars.
2012 F250 TOTALED.
Civilian Contractor Airforce 2+ years Asscrackistan.
2013F250Tank is offline
post #9 of 37 Old 06-02-2013, 06:01 AM
Quoted: 17 Post(s)
Send a message via AIM to rufushusky
A 6R140 is a totally different animal than a 4R100. IIRC the 140 has what effectively works as a thermostat, just like the 5R110 in the 6.0 and 6.4s.
The more basic 4R100 doesn't.
To the OP, on a stock cooler which is about the same size as your keyboard a 100 over ambient temp is pretty normal. A bigger cooler will defiantly help the cause. A 6.0 cooler is a great upgrade, don't get hung up on 31 vs 26 row both work very well and are a huge upgrade over the 9 row 7.3 cooler. Search around online and you can find new ones in the 270-350 range. Mine came out of a junk yard for $100.
2002 F-350 4X4 ECLB 7.3 4R100 6637 filter w/ RiffRaff cover, 08 diff cover, 203* T-stat, HPX, Stancor Relay, 6.0 trans cooler, Zone leveling kit, 8'6" Western Ultramount
Sold: 04.5 Dodge Ram 2500 5.9 CTD, Reg Cab, 48re
rufushusky is offline
post #10 of 37 Old 06-02-2013, 06:48 AM Thread Starter
Thanks for all the input, I have been researching them. I've read that when getting a used one you want to make sure to flush it really good. Seems like I've also gathered there are some aftermarket ones available from places like Summit, but haven't determined what the general consensus is on those.
To jesilvas, I was on divided highway that has some small hills and scattered red lights, not stop and go but not full on moving.
