got a knock - Ford Powerstroke Diesel Forum
post #1 of 3 Old 05-31-2013, 11:12 PM Thread Starter
rcooper919's Avatar
got a knock
I have a 01 f550 with what seems to be a lower end knock, is there a way to pull the pan and replace the mains and rods with out pulling the motor? Is it possible to remove the turbo and motor mounts enough to gain access ?
rcooper919 is offline
post #2 of 3 Old 06-01-2013, 04:58 AM
schlutzer's Avatar
Quoted: 18 Post(s)
A lower end knock is pretty rare on these engines, from what I've seen, you know damn well when you've broke a 7.3 and it wasn't just being nice to it.
Sound like that? its there at idle but likely when driving, peaking in volume around 1500 RPM, especially on a hill or with load?
Injectors, and not much to worry about, extremely common and worried me when I was knew to the 7.3.. My E99 knocks like hell when it's -25C or less.
schlutzer is offline
post #3 of 3 Old 06-01-2013, 05:39 AM Thread Starter
rcooper919's Avatar
Yup, sounds a lot like that !! I have noticed that when I release the clutch and let it idle in neutral some of it goes away as well. It is also more pronounced when warm. I was going to replace the turbo soon with a 38r and was wondering if it would be possible to loosen the motor mounts raise the motor enough to check and possible replace mains and rods. And thanks for the reply
01 SD F550, Rosewood stageII injectors, Rosewood 6 position chip, 6637 filter, 4" exhaust, Autometer Gauges ZF 6speed, 513 gears,waiting on 38r next month, 65mph at 2600 rpms 10 mpg at best up or down hill unloaded or loaded
