Keyless entry? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 05-31-2013, 04:40 PM Thread Starter
Keyless entry?
I'm wondering how to tell if my truck is equipped with keyless entry. I just got the truck and only received one key with it. I would like to get key fobs for it if I can. It's a 99 f350 xlt 4x4 crew cab. Any ideas or anyone with the exact same truck?
Thanks!
tiptonic is offline
post #2 of 7 Old 05-31-2013, 07:03 PM
I would imagine it probably does.
If you're impatient - go to Orielly or Autozone and get a replacement ford keyfob and battery for it - they're like $15.
Then look on here for the keyfob programming sequence. Its something to do with turning the key on and off a couple times, press the locks, press button on remote or something - you'll find it.
If you're not impatient, I've seen the fobs on Amazon.com for as cheap as $3 or $4 at times.
2001 CCLB SRW 6spd - 375K and counting
2003 GMC Yukon - Her baby Hauler
1992 Acura NSX
1997 Honda Civic Hatchback - 2.4 liter, 6266 Turbo
ProOnThaSnow is offline
post #3 of 7 Old 06-01-2013, 02:37 AM
I had the same situation bought a truck only one key on my 01 so I bought some keyfobs and programed them well somethings wrong when I hit the buttons sometimes they work but delayed most of the time they dont work I think I was reading somewhere the G.E.M. box was going bad?
Dubbydoo is offline
post #4 of 7 Old 06-01-2013, 10:33 AM Thread Starter
Well I tried the programming sequence just to see what happened. I turned the key on - off 8 times within 10 seconds. Then the doors are supposed to unlock to verify that the programming mode has been started. No dice, cant get it to verify so maybe the truck doesn't have keyless entry?
tiptonic is offline
post #5 of 7 Old 06-02-2013, 06:55 AM
dieselcrawler's Avatar
Quoted: 23 Post(s)
Not all power lock trks have remote keyless. My trks dont but the Ex does... go figure. Try the key-cycle trick a couple times as it can be finicky. It normally takes me 2-3 trys to activate the system on our Ex...
Sent from my SCH-I200 using AutoGuide.Com Free App
Greg
'99 E350 DRW Stahl 11' util box van, 7.3 PSD, stock. 138k SOLD
'00 F350 extcab, 9' utility bed, dually 228k
E'99 F250 extcab, S/Bed 211k. Sidelined due to motor issues.
'00 Excursion Limited, 7.3PSD 294k
'84 Chevy K-30, 6.2L TD, woods/trail beater. 141k
Semper Paratus
dieselcrawler is offline
post #6 of 7 Old 06-02-2013, 09:45 AM
Quoted: 17 Post(s)
My ex has it, I bought one FOB & got my other from a truck at work. Cycle the key from off to on 8 times within 10 seconds, the door locks will cycle lock then unlock. You then press the lock on the FOB which the door will lock then unlock, then do the the second FOB right afterwards.
2000 Ford Excursion Limited 4x4 Diesel
2007 Jeep Wrangler unlimited on 1 tons & with 41.5" Pitbull Rockers
TBJK is offline
post #7 of 7 Old 06-03-2013, 04:21 AM
Quoted: 23 Post(s)
Make sure you do both/all remotes for that trk... once you reset one, any others not reset at the same time will no longer work. I think you can program up to 4 for the same trk. We had 3 at one time before... down to none now, need to get some.
Greg
Semper Paratus
