deep pan?
Ok I'm about to rebuild my tranny and I'm looking at getting a deep pan. does anyone know where I can get a good deal on one. thanks guys
Zach |
Not sure, but check with Raul at stealth automotive he is a vendor on here and he should be able to hook you up with one or point you in the right direction
Talk to Dennis at ITP Diesel, that is where I got my PML deep trans pan.
I would stay away from the mag hytechs.
Get a 6.0 cooler and either a Hughes or PML. |
If it was me i would skip the deep pan and get a 6.0 cooler or one of the coolers Raul@Stealth has with the electric fan on it
isn't that a little over kill i'm a daily driver i have not had a problem with the trans getting hot
The one with the fan would be a little overkill if you dont tow. Here is the problem with the deep pans though. If the fluid gets hot and it will it takes twice as long to cool it down. The stock cooler cannot keep up with the deep pan
so should i just forget about the deep pan
my trans gets hot sometimes just setting at a idle, ive seen it get to 140 w/o towing and w/o ropping on it! dont know whats up but im interested in a stock 4r100 pan!! I just need a pan for my E4OD with a drain plug lot less mess
