180,000 Mile truck about to drive over 2000 miles, what would you do? - Ford Powerstroke Diesel Forum
post #1 of 21 Old 05-30-2013, 06:41 AM Thread Starter
chrispaine's Avatar
Well I am going to help someone move from Michigan to the West Palm area in Florida. My 2000 F250 has around 180k miles, the last 75k in my possession. The truck runds great and has very little blow by and with a 3000 - 4000 mile oil change the oil is still clean, well not super nasty diesel black like I am used to seeing.
Just wondering what you guys would recomend doing before a trip like this, I don't drive my vehicles this kind of distance often!
What is already done and I think I am good on:
-Had the CPS replaced under the recal a year or two ago
- new brakes (calipers rotors and pads)
-Coolant filter installed
-vented CCV
-both diff fluids have been replaced with amsoil recently
-tcase fluid changed recently
-new tires
-water pump replaced last fall
Plan on doing before trip:
-change transmission fluid
-Obiously I will change the oil right before the trip
-check spare tire
-maybe bring a spare CPS
-coolant flush with ELC and new hoses
-new acc drive belt
Anything else that I am missing?
thanks.
Also, I have two sets of wheels and tires what would you use?
Go in style with the wheels (new tires) in my signature or use my winter wheels? (factory 2008 20" wheels painted black with decent 50% tires and good wheelspacer.com spacers)
2000 F250 7.3L EX.Cab Short Bed -05 Front end w/ HID's - Leveling shackles - Wicked wheel - Dipricol gauges - FORD AIS intake - Foil Delete - LINE-X Rockers - CCV dump - 315/70/17 BFG A/T with Eagle Alloy 197's - ELC w/ coolant filter and around the belt hose - PHP Hydra - Hpress oil x
On the way--
-Fusion front bumper - ATS 3" fender flares
chrispaine is offline
post #2 of 21 Old 05-30-2013, 07:51 AM
cv0lv0g0's Avatar
You covered everything. She's a 7.3 she would probably take it even without those precautions.
cv0lv0g0 is offline
post #3 of 21 Old 05-30-2013, 11:04 AM
rascal's Avatar
Dont know if you have an auto or standard transmission but I have always heard unless you were religious about changing fluid in an auto, and what is in there now has been in there for awhile, don't change it.
Not sure about the autos in our trucks but I had a Buick that the tranny went out soon after I had taken ownership and changed the fluid. Granted the car had been sitting for awhile.
Good luck and nice truck BTW!
Rascal
2000 F-350 XLT ECSB ZF6 4x4
38R+WW | Adrenaline HPOP | Optima | Ravelco | Mag Hytecs | Dynatrac | EBC | Strictly Diesel | AFE | Magnaflow | ISSPRO | DieselSite
rascal is offline
post #4 of 21 Old 05-30-2013, 11:09 AM
mxfever090's Avatar
Run it and try to stay awake through Indiana, Georgia and northern Florida. Very boring areas for a long drive.
This would be a great time to do a fuel mileage study based on tuner setting, speed, and towing wieght
Jason
O.T.F.D. Volunteer 19
Great White - 2003 7.3l F-250 4x4 CCSB -102,000 miles and tickin
DIY intake - 4" Straight pipe - HPX - CAT ELC - 203 t stat - billet t stat housing - coolant filter - dual alt radiator hose - 12V Air compressor - 5 gallon air tank - Air line quick connects - AIR HORNS!
Hers: 2013 VW Jetta TDI
mxfever090 is offline
post #5 of 21 Old 05-30-2013, 11:50 AM
cv0lv0g0's Avatar
+1 this is a good idea.
cv0lv0g0 is offline
post #6 of 21 Old 05-30-2013, 11:51 AM
Just drive it and enjoy!
In all honesty, it looks like you've got pretty much everything covered. You may, however, want to check your serpentine belt tensioner and idler pulley when you replace the belt.
2000 F350 4X4 CCSB w/ 7.3 and 4R100
PIS 175/80, Adrenaline HPOP, 4" Exhaust, 6637 Filter, CCV Mod, Leveled Front, 315/75/16 Goodyear Duratracs
Devil Car is offline
post #7 of 21 Old 05-30-2013, 02:57 PM
'01SilverBullet's Avatar
Quoted: 4 Post(s)
If you change the belt, throw the old one under the seat as a spare, and take a 1/2 inch drive breaker bar to change it. If you decide to throw new coolant hoses on it, get the upper one for a truck with dual alternators, because that will go around the belt, not through it, making it possible to change the belt roadside, without having to open the cooling system.
Maybe throw a new air filter at it, if it's getting pretty dirty. Mostly for mileage
I'd jack the front end up and check your ball joints and steering linkages for play. Also check the wheel bearings, spin them, too. I know I had one that was starting to get a couple tight spots awhile back.
As far as the tires go, I'd go with whichever ones give you better mileage, 2000 miles, that adds up quick, especially with 4 dollar diesel. But, your summer rims do look pretty badass
2001 F250, 7.3, Automatic, 4x4, 33's, Leveled, Cobra 29 CB Radio, Dual Firestick Whips, Pioneer Head Unit, Riffraff 6637 Intake Kit, 4" turbo-back straight pipe, Dual Alternator Upper Radiator Hose, AutoMeter Boost, Pyro, Trans Temp, Delta Toolbox, Gooseneck Hitch and a heavy right footed driver...
Wishlist: 160cc single shots, GT38r, BTS, SRP 1.1
REAL TRUCKS DON'T NEED SPARKPLUGS!!
Lord, please take care of this drivin' fool...
'01SilverBullet is offline
post #8 of 21 Old 05-30-2013, 04:58 PM
t-ray-4ray's Avatar
Quoted: 79 Post(s)
One thing overlooked allot, break out a grease gun and grease the front end I do this every other oil change
Sent from AutoGuide.com App
2000 f-350 4x4 extended cab, went from a flatbed work truck to what you see now, all done by me. Early 99 engine, billet low stall converter, rebuilt trans, all new uvch, new belt tensioners and idler pulley, rebuilt injectors, all new icp, idm, cps, hutch mod, k&n intake, white valve covers, wicked wheel, 5 inch exhaust, php hydra chip 15pos, 8" superlift, 20 inch black and machined rims, 2" billet spacers, 37/13.50r20 toyo open country tires, rough country dual stabilizer, 05 front end with 10k hid lights, amber led cab lights, 09 ford van bucket seats, 2010 f150 center console, b&m ratchet shifter, aero force scan gauge, b&m trans cooler used as a fuel cooler,
t-ray-4ray is offline
post #9 of 21 Old 05-30-2013, 05:20 PM
goats's Avatar
Quoted: 2 Post(s)
My last trip from west palm to Atlanta I had to change my alternator on the side of the highway. My truck only has 130k
goats is offline
post #10 of 21 Old 05-30-2013, 07:30 PM
Quoted: 17 Post(s)
Personally I would not change the trans fluid unless you have kept on intervals with changing it. Look at the color in a paper towel, smell it. If its not red & smells burned I would be cautious. If you change the fluid & it hadn't been done before the clutch disks will begin to fail & slip. Check your battery terminals & connections. Clean your exhaust back pressure tube. Bleed your brakes & change your power steering fluid (so you have optimum hydro boost)
2000 Ford Excursion Limited 4x4 Diesel
2007 Jeep Wrangler unlimited on 1 tons & with 41.5" Pitbull Rockers
TBJK is offline
