EBPV Tube? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 05-28-2013, 08:10 PM Thread Starter
Mchek's Avatar
EBPV Tube?
Hey guys so last night i was cleaning the ebpv valve sensor and tube and when i got the tube off noticed it had a crack and a rather large hole in it, so after doing of few other things that needed to be done i went inside to start looking online to see how much this damn tube was going to be well i couldnt find it, i tried orielly auto parts, autozone, and even fords part website and it wasnt there. so i was wondering if anyone else has had to replace this and if they know the part number or at least where they found it.
Early 1999
F-250 CCSB Automatic 7.3L POWERSTROKE
1982 GMC Sierra Classic 1500 6.2L diesel
1977 Dodge Power Wagon 318ci
Mchek is offline
post #2 of 10 Old 05-28-2013, 09:22 PM
Joel's Avatar
Quoted: 10 Post(s)
i dont know the part #
But I do know that some fellows make it themselves from a brake line for like $5
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #3 of 10 Old 05-29-2013, 04:00 AM
Quoted: 13 Post(s)
Feedback Score: 3 reviews
Guzzles site dieselorings.com has them
2000 F250 XcabSB, 4x4, 4" strait pipe, DIY intake, FRx, BDP tunes, WW2, 6.0 cooler, BTS VB, gauges, 55w digital projector HIDs
gomer pyle is offline
post #4 of 10 Old 05-29-2013, 05:28 AM
Eco Taxi's Avatar
not to hijack but with a related item - what should your psi be for your exhaust back pressure? I cleaned my tube and sensor awhile ago because they were both completely clogged and now i have a scan gauge and see an average of 40-42psi. Wondering if this was normal ?
Kyle
2001 F350 Chassis Cab 4x4 DRW Flatbed 130k miles+
Quad Gauge Pillar - Aeroforce Interceptor & Glowshift Series 7 EGT, Boost, Trans Temp
Foil Delete | Marinco Mod | High Torque 4kw Starter | Door Seal Mod | AIH Delete | Coolant Filter & 203* Thermostat w/ Billet Aluminum Housing | Hutch Mod | RiffRaff Fpx, Hpx, boots | WW2 | Deleted ebpv
“The good thing about science is that it's true whether or not you believe in it.” ― Neil deGrasse Tyson
Eco Taxi is offline
post #5 of 10 Old 05-29-2013, 06:14 AM
Mine runs 14.7 at idle.
celltech is offline
post #6 of 10 Old 05-29-2013, 07:22 AM
Joel's Avatar
Quoted: 10 Post(s)
Depends what you're using to read it.
My insight takes off atmospheric pressure in the reading so mine reads 0 at idle and very low at cruising speeds.
14.7 at idle would be the equivalent of a zero reading because you device is reading atmospheric pressure.
In any case, a reading of 40 is off, unless that's under load, and you should replace the sensor.
Joel is offline
post #7 of 10 Old 05-29-2013, 04:49 PM
blue99stroker's Avatar
Quoted: 247 Post(s)
cheapest ive seen is ebay.
was like 30-40 bucks.
i bought mine from ford for about 70-80
99.5 f250 7.3 4x4 260k FF 160/30, PHP Hydra, S&B CAI, 4" Exhaust, RR Billet Wheel, Autometer Gauges, Transgo, Non-Ebpv Pedestal, High Flow Outlet, 08 Tow Mirrors.
Dad-2000 7.3 4x4 110k miles, Autometer Gauges, Superchips 1705, 6637, 4" Exhaust, BD Billet Wheel, TruCool Max
blue99stroker is offline
post #8 of 10 Old 05-29-2013, 06:17 PM
Quoted: 13 Post(s)
DieselOrings: Exhaust Back Pressure Replacement Tube 99.5 - 03 7.3L Diesel
$40 and it is an OEM part
post #9 of 10 Old 05-29-2013, 08:07 PM Thread Starter
Mchek's Avatar
Ok, thanks everyone! I think i might go check out some salvage yards for one before i drop $40 on a new one. And then later down the road when i have the money get a new one.
Early 1999
Mchek is offline
post #10 of 10 Old 05-30-2013, 11:25 AM
Quoted: 247 Post(s)
ones in the salvage yard probably are cracked or have holes as well.
i would just do it once then be done with it.
it wont be a huge issue right now. you might be losing a little mpg but your truck is gonna run fine.
