Runs rough at idle update. - Ford Powerstroke Diesel Forum
post #1 of 7 Old 05-28-2013, 04:34 PM Thread Starter
Sorry couldn't find my other post so Il just start over again. New injector cups injector o-rings, 2 new injectors, new valve cover gaskets,ipr,cps, icp, and now a new rebuilt idm. Just a little bit of change runs better once again like after I have done all these things but it still isn't right. I have ohmed out all wire from idm to injectors and all is good there so I know the wiring is good.
Here is a couple weird things that happend recently. With edge chip unplugged P1316 would go away. Put a tune on it and it comes on. Wasn't doing this before.Now after a while of driving it stock the P1316 will come on but takes a while. I put new idm in and soon as I rev it up a little it comes on right away with no tune installed.. So I put the old back in and cleared codes and P1316 doesn't come on after I rev it up. Put new one in and right away its back. Do I need to have the code cleared by ford to see if it stays away. Is it just engrained into the memory.
Next thing I was thinking about was could someone have left a tune on the truck before I got it so when I put the edge chip in it it completely is just messing things up. I am at a loss and looking for anywhere or anything to try next.
Everything has been replaced due to codes that have been pulled. I have not just been throwing this part in and that part in. Last time at ford got told wiring or under valve cover gaskets must be bad even after I told them there new and I ohmed out the wires so Im done with them.
redsmoke is offline
post #2 of 7 Old 05-28-2013, 04:40 PM Thread Starter
Forgot to say how it idles. It idles rough enough to shake truck. Almost like it has lope but not that bad. Instead of a mmmmmmmm smooth idle its like rum rum rum rum.That probably doesn't make sense. If I could upload a video I would. But as soon as you take off its fine. Runs fine on highway and no miss or lack of power. MPG are way down though.
redsmoke is offline
post #3 of 7 Old 05-28-2013, 05:54 PM Thread Starter
Okay so tried something else. I have three cps sensors. A borge warner, a delphia, and the grey ford one. I put the delphia one in it and seem to smooth out the idle big time. But missed horribly when trying to drive and wouldn't go down the road. Put the old ford grey one in it and better idle not great though. Rough idle with borge warner.
So am I just having a big issue with the cps sensor. I never get a code for it just tried these a long time ago and still had them so though about playing with them again.
On the upside the P1316 code went away. Anyone have any thought on which cps to have beside the old black one you can't get anymore.
redsmoke is offline
post #4 of 7 Old 05-29-2013, 03:54 PM
blue99stroker's Avatar
Quoted: 272 Post(s)
looks like dfuser has some international ones.
i would try one those they are 40 bucks.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #5 of 7 Old 05-30-2013, 08:47 AM
First off make sure there is no corrosion on the mating surface for the CPS that will throw off the reading. At the dealership I have had major problems with aftermarket CPS sensors and the distance they are from the tone ring even 1 thousands of a difference will cause running issues. The only CPS I advise is ones from international or ford.
Sent from AutoGuide.com App
Jduff27 is offline
post #6 of 7 Old 05-30-2013, 10:27 AM
Quoted: 272 Post(s)
i think the international one is still black.
its just more expensive and hard to find.
dfuser is the only place ive found that has any.
post #7 of 7 Old 05-30-2013, 12:52 PM
The black one had a recall on it and it was switched to the grey one with the gold bracket
Jduff27 is offline
