dana 50 vs. dana 60??? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 03-06-2008, 09:37 PM Thread Starter
krupatex's Avatar
What are the differences in the 50 and 60 and are they that big of a difference to even be concerned with???
-2000, 7.3 F250 4x4 LB-
2" Suspension Lift
Straight pipe exhaust (NO Kitty)
FLAT BLACK 6"STACK!!!!!
ZOODAD
CCV MOD
Waste Gate delete
DIY Tymar air filter system
AGR Ford Super Pump
Front Sway Bar Quick Disconnects (ARTICULATE LEAFS!!)
..."Texan born and bred".....
-Weatherford/Fort Worth-
krupatex is offline
post #2 of 9 Old 03-06-2008, 10:00 PM
99bigred's Avatar
from what ive heard the dana50 gears are alot weaker then the 60. dont know about the axle shafts though
early 99 f-350 7.3 6speed crew cab
banks exhaust, chip, big head, exhaust houseing
and wheel
Ford AIS intake
5.5" fabtech lift w/ 35x12.50/18's
99bigred is offline
post #3 of 9 Old 03-07-2008, 12:22 PM
sirnunya's Avatar
dana 50 pretty much has a dana 60 outside with dana 44 internals
sirnunya is offline
post #4 of 9 Old 03-08-2008, 05:08 AM Thread Starter
krupatex's Avatar
so is that gonna effect me much if I run big tires???
2" Suspension Lift
ZOODAD
CCV MOD
Waste Gate delete
AGR Ford Super Pump
krupatex is offline
post #5 of 9 Old 03-08-2008, 05:17 AM
todd's Avatar
that axle can handle any tire you can fit under that truck
traded it for an 06 dodge sorry
todd is offline
post #6 of 9 Old 03-08-2008, 05:44 AM Thread Starter
krupatex's Avatar
I figured, but just thought I would ask for that warm and fuzzy! It's still a big azz axle, shaft and for sure the housing.
2" Suspension Lift
ZOODAD
CCV MOD
Waste Gate delete
AGR Ford Super Pump
krupatex is offline
post #7 of 9 Old 03-08-2008, 07:45 AM
John Wood Nut Swinger
strokin_early_99's Avatar
The stock axles take a heck of a lot of abuse by the big power guys and they don't brake axles or transfer cases. Well, there is one transfer case that blew up and that was by Elmo at the diesel power challenge. That is the only one I have herd of. Axles take a lot of abuse. Every once in a while the front U joint will let go when either drag racing or sled pulling but other than that the ford drive train is pretty stout.
As I understand it, the D50 solid front axle is actually a D60 housing with D50 innards.
(Born on 11-20-98) F350 CC LWB 4X4
north of 480hp and south of 13.7sec
Bored with current setup
Family of 5 saved by Grace.....
Sponsored by Left Coast Diesel in Concord, Ca
Anything BUT Conservative Performance
strokin_early_99 is offline
post #8 of 9 Old 03-08-2008, 06:22 PM
99bigred's Avatar
we have broke a d60 stub shaft....at pismo
and wheel
Ford AIS intake
99bigred is offline
post #9 of 9 Old 03-08-2008, 08:23 PM
Now that you mention it, I think I remember John Wood saying he broke an axle shaft while he was being filmed for diesel power magazine.
