DIY Tymar vs. AFE Stage 1? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 03-04-2008, 11:11 PM Thread Starter
mmcf's Avatar
I currently have an 01 f250 with what i believe is an AFE Atage 1. Thinking about installing the Tymar DIY with the Zoodad mod. Is this a wise decision?
2001 Ford F250 4x4 Crew Cab Long Box
8" Fabtec Lift
Dual Front ProComp Shocks
Rancho Steering Stabilizer
355/70 R17 Toyo AT
2" Wheel Spacers
4" Stainless Steal Exhaust
AFE Stage 1 Intake
10K MOD (4.7k version)
Foil Delete
DIY OBS FPR Shim
Bed Lined Rocker Panels W Pinstripes
Tinted Windows
Leather
Support Your Troops
USMC Scout Sniper 97-05
mmcf is offline
post #2 of 7 Old 03-04-2008, 11:32 PM
John Wood Nut Swinger
strokin_early_99's Avatar
Why would you do this? Get the torque tube from AFE and make it better. The zoodad mod will help get cold air into the intake you have. With the tymar intake the zoodad does not do that much to get cold air into the filter like your current system.
https://www.shopatron.com/product/pr...54-10199/534.0
(Born on 11-20-98) F350 CC LWB 4X4
north of 480hp and south of 13.7sec
Bored with current setup
Family of 5 saved by Grace.....
Sponsored by Left Coast Diesel in Concord, Ca
Anything BUT Conservative Performance
strokin_early_99 is offline
post #3 of 7 Old 03-04-2008, 11:42 PM Thread Starter
mmcf's Avatar
Makes sense.The filter i have is an oiling type, and quite a bit smaller than the tymar. From what I was reading earlier i thought the tymar filter was better. I must have mis interpreted it. Thanks
8" Fabtec Lift
355/70 R17 Toyo AT
2" Wheel Spacers
AFE Stage 1 Intake
Foil Delete
DIY OBS FPR Shim
Tinted Windows
Leather
Support Your Troops
mmcf is offline
post #4 of 7 Old 03-05-2008, 12:02 AM
The tymar/Napa filter is better than stock but I don't necessarily think it is better than your AFE. Maybe a little better filtering but it won't flow any more air since all the air is squeezed through the stock intake tube anyway. In addition your current system pulls cold air and the tymar will suck in heated air. Colder denser air makes more power. Your flow is only as good as your biggest restriction. Your CCV block is your biggest restriction in the intake, IMHO.
post #5 of 7 Old 03-05-2008, 06:54 AM
Powerstroke Techie
alabamafrog's Avatar
I still want to see some real data on the two filter styles. To me the most important thing is filtering (I got my engine dusted by the factory filter), I want to know the micron level and efficiency of the filters as well as the flow ratings. The AFE looks similar to the K&N to me and I have seen K&N cone style filters leak dust. If I can’t have real data then I have to make an opinion based on appearance and logic. The DIY is way bigger than the AFE or K&N. It looks to me like it would filter better based on surface area, they say it flows better, how can something smaller flow more without filtering less?
“Government, even in its best state, is but a necessary evil; in its worst state, an intolerable one” (T Paine)
Government cannot give anyone anything without stealing it from someone else. (A Frog)
alabamafrog is offline
post #6 of 7 Old 03-05-2008, 07:13 AM
Desert Shield/Storm Vet
vitalidle's Avatar
I think the key to an oiled filter is to keep it clean and make sure you get the whole surface area oiled. I believe you can't go wrong with either filter, but my personal preference was the tymar or nappa filter because of ease of maint., and those oiled filters always look dirty. If you have the AFE now keep it unless you want to get away from the oiled filters go with an
AFE dry filter or a nappa/tymar.
2002 F-250 4x4 EC, SRW, SB
Auto 93,000 miles
DP Tuner F5
ATS Compressor and 1.0 Exhaust housing high flow back plate
Turbo Back 4" Silverline Exhaust Mbrp Muffler Delete
Isspro Trans,Pyro,Boost Triple Pod
Fumoto Oil Drain Valve
AIH Delete With Boost Fitting
vitalidle is offline
post #7 of 7 Old 03-05-2008, 10:42 AM
All I can say is my AFE oiled filter does not leave any dusty residue like the K&N did when I ran one for a little while. The intake is nice and clean, and I wipe it with a white T shirt to see just what is in there when I do inspect it.
I can also tell you that my filter sees 1770cfm of air flowing through it at 53psi of boost. A stock truck will see 1040cfm of air past the filter at 25psi of boost. This is actual data taken at the NADM event in Bakersfield, Ca by a Cal Poly engineering student.
