i just replaced my up pipe gaskets with some carquest brand ones and i still have a leak. i tightened the bolts down as hard as i could. is there a way to tighten them without pulling the turbo again and also is this why my boost is reading way lower than usual and drops instantly when i let out of it? thanks for any help
I went with the bellowed up pipes and did away with the donuts. no more leaks
Your boost being low sounds like something is leaking check anything you unbolted and retighten. |
Did you use a new white seal when you did the carquest donuts?
no. i used some grey lead looking color gaskets
hmmm The ones from Ford are white... where did you get the gray ones?
they are carquest brand
If they leak, you did not tighten them enough. I have over 50psi of backpressure and there are no signs of leaks for the last 6 months. I have put these in a few trucks now without any problems.
They should be grey/silver. They are graphite. I have not seen the white ones before. |
