01 getting hot, and dont know why! - Ford Powerstroke Diesel Forum
post #1 of 52 Old 05-14-2013, 11:33 PM Thread Starter
LJT
LJT's Avatar
Quoted: 2 Post(s)
this winter stock up-pipes started leaking bad so i had to get them fixed and decided i wanted to give it a little make over at the same time and this is what it consisted of.....
international stainless bellowed up-pipes
k&n cold air intake
38r turbo
cfm intake
stiffer fuel spring
full turbo back 4in straight
php retuned chip
t500 hpop
cts insight
i still have stock injectors. i also still wanna add a boost fooler. ill end up doing new injectors at some point but have yet.
most of what i added i thought would help lower egts, but i still run right through the 1200's, 1300's, and right into the 1400's. i was doing a 1/4 mile time with my performance part on my cts so i couldnt c my egts and afterwards i go back and c that my max recorded egt was 1510!!!!! ive recently considered a water/meth kit to help with the heat but i feel it shouldnt be high to begin with, am i correct? and also its only on the 140hp tune, the 75 daily driver and 75 tow tunes are fine. the 100hp race starts to get warm as well
fuel psi is like 115psi
icp at wot is about 3000psi
the truck has 225,000 and starts fine and runs fine, just dont know why its getting hot. also i feel like it should have a llittle more top end than it does, perhaps the boost fooler well help that...im hoping.
any ideas guys?!
LJT is offline
post #2 of 52 Old 05-14-2013, 11:53 PM
Justin@DP-Tuner's Avatar
Quoted: 54 Post(s)
Originally Posted by LJT View Post
so heres the whole story,
i bought this my 01 f250 last october. it had 218000 miles on it and had a k&n cold air intake, ts 6pos. chip and a catback 4 in exhaust.
38r turbo
cfm intake
stiffer fuel spring
php retuned chip
t500 hpop
cts insight
the truck starts fine and runs fine, just dont know why its getting hot. also i feel like it should have a llittle more top end than it does, perhaps the boost fooler well help that...im hoping.
any ideas guys?!
There are many reasons for high EGT's. The first thing to check would be for any boost leaks. Your tuning may need adjustment as well.
Your fuel pressure is WAY to high. Ideally it should be around 65psi.
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
post #3 of 52 Old 05-15-2013, 12:00 AM Thread Starter
LJT
LJT's Avatar
Quoted: 2 Post(s)
heres my baby!
Name:	2012-09-25 19.23.09.jpg
LJT is offline
post #4 of 52 Old 05-15-2013, 12:02 AM Thread Starter
LJT
LJT's Avatar
Quoted: 2 Post(s)
cant find any boost leaks, none from up-pipes.
i also at the same time put a bd boot kit on and they are holding strong as well.
would that fuel psi cause high egts?
php tunes get great reviews, seems weird why they wouldnt work on my truck
LJT is offline
post #5 of 52 Old 05-15-2013, 05:11 PM Thread Starter
LJT
LJT's Avatar
Quoted: 2 Post(s)
nothing???
LJT is offline
post #6 of 52 Old 05-15-2013, 10:41 PM
Quoted: 54 Post(s)
Did you pressurize the system to confirm that there are no leaks?
High fuel pressure will not cause high EGT's necessarily, but it will take a toll on the injection system. Try putting the stock spring back in and monitor your pressure. Maybe your gauge is just defective?
DP-Tuner
Like us on
Justin Bochmann
post #7 of 52 Old 05-16-2013, 08:43 AM Thread Starter
LJT
LJT's Avatar
Quoted: 2 Post(s)
Justin,
I have not pressurized the system. All ive done was during warm up before everything is hot just feeling with my hands around all the seams. So to the best of my knowledge it isn't leaking. Whats the procedure to actually pressurizing it to make absolutely sure?
I don't think I have the stock fuel spring anymore! haha, I think I threw it away. I don't think the gauge was defective, although its possible. The one that was used was out of a very expensive fuel system pressure test kit. I drilled and tapped a hole on the top of my fuel filter and threaded it into that. So at that point the gauge was showing over 100psi. Obviously a new filter was put back in when the testing was done.
LJT is offline
post #8 of 52 Old 05-16-2013, 08:47 AM Thread Starter
LJT
LJT's Avatar
Quoted: 2 Post(s)
this is the spring that I put in, a local diesel shop turned me onto this product.
GDS Fuel Spring
LJT is offline
post #9 of 52 Old 05-16-2013, 08:59 AM
Quoted: 54 Post(s)
Justin,
The best way to do it is to use shop air. Google "boost leak test" and you will get results showing you the procedure. Here is also a video to show you how.
The spring may also be installed wrong. If it is not seated properly you will get undesirable pressures as well.
DP-Tuner
Like us on
Justin Bochmann
post #10 of 52 Old 05-16-2013, 09:18 AM Thread Starter
LJT
LJT's Avatar
Quoted: 2 Post(s)
o man, that's probably one of the simplest things ever! thanks for the vid Justin.
95-110 psi is right were the spring was designed to put the fuel pressure. I called the guys at GDS and they said 100+ psi is normal and right where you want it. Hmmmmmmm????
What part of the injection system is gonna get beat up by that amount of psi?
LJT is offline
