Old 03-02-2008, 10:07 PM
Mikes7.3 Mikes7.3 is offline
6.0 Intercooler
I have a minor problem when swapping 7.3 w/ 6.0 I/C the trans cooler line is in the way won't allow to sit all the way down. There are 2 lines 1 I can move the other is attached w/ a fitting on top (passenger side) all I need to do is back that fitting off about 1/4 turn but the fitting doesn't look like it has threads, and I don't want to break it. Any input would be helpful otherwise I'm going to move the trans cooler over. (a lot more work)
Old 03-04-2008, 09:29 PM
"Note on some models trans cooler lines need to be re-routed".
I found this on the spearco I/C install. Should be added to GCOP'S install swap of 6.0 I/C to 7.3 in the TECH SECTION if He doesn't mind. bending won't work on mine.
Old 03-04-2008, 09:49 PM
mschn99 mschn99 is offline
might want to send tony a PM to have him edit his post in the tech files..
Old 03-04-2008, 10:01 PM
Done
Old 03-04-2008, 10:24 PM
CSIPSD CSIPSD is offline
I dropped mine with a drop bracket... Very easy to make if you have a welder...
File Type: jpg drop bracket for Tranny and PS coolers.JPG (47.0 KB, 19 views)
Old 03-05-2008, 09:31 AM
southmike southmike is offline
if you were adding a 6.0 IC and changing the tranny cooler to say a trucool or v10 style cooler would you still have the problem?
just wondering for future mod installs.
Old 03-27-2008, 07:25 AM
did more digging if you added a 6.0 ic on an early 99, where the tranny lines do not go into the radiator , do you think you would have to drop it.
meaning are you moving the IC because of lines in the way or is it just too tall.?
Old 03-27-2008, 04:14 PM
Sinac Sinac is offline
When I installed my 6.0 intercooler it slid right in, I didn't have to move any hoses?
