  #11 (permalink)
Old 03-02-2008, 09:58 PM
fords4life fords4life is offline
Originally Posted by 06Blackmamba View Post
Brake cleaner eats rubber damm
Stock intercooler tube boots are silicone right? The rubbing alcohol is awesome on silicone!
  #12 (permalink)
Old 03-02-2008, 11:38 PM
06Blackmamba 06Blackmamba is offline
Send a message via AIM to 06Blackmamba Send a message via Yahoo to 06Blackmamba
brake cleaner and silicone mixed to gether is Bracone hahahah omg ahhhahh ok im going to bed ive had enough beer and enough about raul and dana 60s
  #13 (permalink)
Old 03-03-2008, 04:05 AM
Jonathan734 Jonathan734 is offline
Lol I use hairspray to hold the grips on all of my race bikes, who needs glue?
  #14 (permalink)
Old 03-03-2008, 12:55 PM
Marty Marty is offline
International Threat
I didn't read any responses, but here's my advice.
Take off all of the boots and the two I/C tubes.
Soak the boots in something like simple green, and then scrub them clean. Allow them to completely dry.
While they're drying, clean off the tube on the outside really well and a little bit on the inside. You can scuff up the surface where the boot comes over and then coat it with hair spray. This will make it sticky and the boot will actually "grip" to the tube.
Put the boot on the tube, and then the first clamp and tighten that down to around 70 ft/lbs. Make sure it's a SPRING T-BOLT CLAMP or constant pressure clamp. A regular hose clamp will not suffice here. Then install on truck and add the next two clamps per tube. You should be good to go until you order some from www.dieselsite.com
