Old 03-02-2008, 11:15 AM
Strokethis9 Strokethis9 is offline
What code is this
I have my truck set on the 60 economy tune and when i get on it untill like 70 or so my check engine light comes on and the code its throwing is P0603 and it says powertrain keep alive what does this mean im so lost
Old 03-02-2008, 11:17 AM
Dave Dave is offline
Obama sucks
Is that the only code coming up or are there more. That code is common when you change tunes. I bet if you look further you will see a p1211 code because the HPOP isnt keeping up or P1249 overboost code setting the CEL off
Old 03-02-2008, 11:20 AM
it threw p0603 and a nother about about a wastegate or something but it always comes up as long as my chip is in
Old 03-02-2008, 03:50 PM
strokin_early_99 strokin_early_99 is offline
John Wood Nut Swinger
The KAM is a code that gets thrown if you have a chip in the PCM. It does not happen if you are using a tuner. I have one every time I read my codes. NO big deal at all.
Do you have the wastegate disconnected or unplugged? Is the electric solenoid on the intake Y unplugged?
Old 03-02-2008, 04:14 PM
vitalidle vitalidle is offline
Desert Shield/Storm Vet
Mine gets set by my superchips tuner
Old 03-02-2008, 04:29 PM
bigwhite7.3stroker bigwhite7.3stroker is offline
Florida Stroker
I pulled the same code the other when I checked for the heck of it but sounds like no big deal, thats good to know
Old 03-02-2008, 04:35 PM
strokerboy73 strokerboy73 is offline
Was wondering if you could explain on the chip in the PCM. What is done exactly?? I just bought a 95 that throws this could. KAM (keep alive memory). Just would like to learn more about it. Thanks.
Old 03-02-2008, 04:58 PM
lamarmathis lamarmathis is offline
i believe it will set the code anytime the batt voltage gets below 10.5,especially when starting
Old 03-02-2008, 05:22 PM
no i dont have the wastegate unplugged i plan on unplugging it once i get my gauges installed i just need to put them in because i got them
