Transmission Fluid Change Procedure - Ford Powerstroke Diesel Forum
post #1 of 5 Old 05-13-2013, 04:49 AM Thread Starter
Might someone have a transmission fluid change procedure they could point me to? I think I have seen one before but did not print it or bookmark it.
Thanks in advance.....
2002 F250 CC SB 4x4 7.3L
186K Miles
CCV Mod
Fluidampr
PHP Hydra
RiffRaff FRx
AFE Stage 2
Wicked Wheel 2
Adrenaline HPOP
Evans NPG Coolant
Aeroforce Interceptor
Mishimoto Intercooler
6.0 Transmission Cooler
Red Head Steering Gear
4" Turbo Back Magnaflow
International Bellowed Up-Pipes
Dieselsite Legendary Transmission
2 Corinthians 5:15 - "and He died for all, so that they who live might no longer live for themselves, but for Him who died and rose again on their behalf"
PreciousMetals is offline
post #2 of 5 Old 05-13-2013, 11:01 AM
hansel's Avatar
Quoted: 100 Post(s)
What I do is remove the return line at the front of the truck right at the cooler, and will pump 1 gallon out, then replace it. I do this until I've changed 3 gallons, I do this every 15,000 miles and then at 30,000 miles I will change out 5 gallons which will completely change all the fluid. Then when I hit 60,000 miles drop the pain and flush the tranny.
2001 7.3L CCSRW 4X4
Airiad Intake 4" Flo-Pro Exhaust
ISSPRO EGT/Transmission
PHP Hydra
2015 Heartland Prowler
hansel is offline
post #3 of 5 Old 05-13-2013, 05:56 PM
Zaairman's Avatar
Quoted: 12 Post(s)
Drain pan. Drain converter. Refill. Done. True, it doesn't get *all* of the fluid out, but you'll get most (14 quarts or so I think, don't remember exactly).
Zach
2000/2006ish Ford F-250 Larryette 7.3 Powerstroke 4x4
5" Sewer Pipe Exhaust
, DIY 6637 Intake, Wicked Wheel'd, De-foiled, Missing EBPV, Edge Juice with Attitude, Few leaves added here and there, 35" BFGs, 16x10 Eagle Alloys, Alpine W200
SLAPS Member #153
Zaairman is offline
post #4 of 5 Old 05-15-2013, 04:51 PM
ive done pan and converter last week.17 quarts if I remember correctly.but didn't they stop the drain plugs in the converter in 01?
adams01 is offline
post #5 of 5 Old 05-16-2013, 03:53 AM
Quoted: 17 Post(s)
Send a message via AIM to rufushusky
Yes somewhere around there they stopped offering service plugs on the converter. I drained the pain, refilled it, disconnected the cooler return line and pumped out a gallon, added a fresh gallon..etc etc until I went through 20 quarts. Seems to get the job done, I do it around every 30k (almost annual)
2002 F-350 4X4 ECLB 7.3 4R100 6637 filter w/ RiffRaff cover, 08 diff cover, 203* T-stat, HPX, Stancor Relay, 6.0 trans cooler, Zone leveling kit, 8'6" Western Ultramount
Sold: 04.5 Dodge Ram 2500 5.9 CTD, Reg Cab, 48re
rufushusky is offline
