- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
Removing passenger VC
Well I am pulling my valve covers to check harnesses and install some a new injector on each side, what all has to come out to get the passenger side off? Anyone have any pics? I can access all of the bolts now except for the most rearward and bottom bolts. Really need some help on this guys thanks!
| Sponsored Links |
Alright I got the passenger VC off and now I am getting ready to put in my two new injectors, 3 and 8. I am also replacing the glowplugs and UVC harnesses. What is the best way to clear the motor of oil? Which fuse do I need to pull to shut off the IDM? Do I need to drain the Crankcase to do this? What about opening up the oil rail? Thanks.
Anytime you remove an injector you need to do that. You just need to remove all the nuts, all 13 mm (a 13 ratchet wrench makes life easy on the two by #'s 5 and 7). The coolant hoses also come out of their clips, and then use a screw driver to pry the clips from the bottom and they'll pop off. You'll also have to remove the I/C pipes... |
I've done it both ways. The last time I had to replace a single injector, I did not drain the oil line. Once the new injector was in, I turned the motor over (by hand) with the glow plug out. Then waited a few minutes, then cranked the engine over with the starter. Replace the glow plug, then crank the motor over for about 30 seconds. Button the motor back up, then crank the motor over for another 30 sec (both times done at the solenoid). If you've never done this before, take the safe route and drain the oil line. |
i'll take this to pm's to keep from derailing this thread so much.
| Sponsored Links |
