P0470 Code Help - Ford Powerstroke Diesel Forum
post #1 of 2 Old 05-12-2013, 03:38 PM Thread Starter
AnthonyU's Avatar
Quoted: 8 Post(s)
P0470 Code Help
I am getting this code and wonder if it caused by my chip (PHP) or if the sensor is bad I cleaned the tube the best I could. Also notice after WW2 install egt's are up like 200 degrees not sure if its this or what any help or thoughts would be helpful.
AnthonyU is offline
post #2 of 2 Old 05-12-2013, 07:59 PM
blue99stroker's Avatar
Quoted: 258 Post(s)
if your egts are up you probably didnt put the turbo back on correctly.
check the band clamp on the back of the turbo and check to make sure the downpipe is on correctly.
also check all the intercooler boots on the intake manifold.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
