Old 03-01-2008, 05:53 AM
ice ice is offline
New to Forum and New to PSD 7.3
Hi Guys, I am new to the forum and have just purchased a 2001 7.3 PSD. Questions I have are my truck when it is cold will act like it has a miss running down the road 45-55 mph. Doesn't neccessarily need to be under a hard accelaration. It also has a hissing noise until it warms up also, almost like a valve is shutting. The truck came from up north around Milwaukee and another guy told me that they have a different set-up such as a heat riser would work on the older gas engines? Any suggestions would be appreciated. Also the speedo is off about 6 mph, can the dealer fix this? Thanks Again!
Old 03-01-2008, 05:56 AM
westcoaststrokin westcoaststrokin is offline
Go Navy! Beat Army!
to the ORG!!
Old 03-01-2008, 05:58 AM
rankroddin250 rankroddin250 is offline
the hissing is the exhaust back preasure valve. I disconected mine. its a 2 wire plugin found on the under side of the turbo compresor housing.
the missing might posbily be a bad injector or a bad conection on the under valve cover wiring harness going to the injectors. might have an injector buzz test done.
the dealership should be able to recalibrate your speedometer. if not you will have to get some thing like tru speed or speed wizard to compensate for it. any off road shop should be able to hook you up with one of those but id check the dealer first.
to powerstroke.org
Old 03-01-2008, 05:59 AM
Dave Dave is offline
Obama sucks
Welcome to the site. The hissing noise is the EBPV closing to aid in engine warm up. Its perfectly normal. Some people disconnect it. Also are there larger than normal tires on the rig. That may be why the speedo is off
Old 03-01-2008, 06:06 AM
Evil Eye Evil Eye is offline
Slacker Mod
Welcome to the ORG! It sounds like you've gotten some great info so far.
Old 03-01-2008, 06:08 AM
HeavyHauler HeavyHauler is offline
She's paid for!!!!!!
Old 03-01-2008, 06:21 AM
bigwhite7.3stroker bigwhite7.3stroker is offline
Florida Stroker
WELCOME TO ORG! ! !
Old 03-01-2008, 06:24 AM
pipelayerjdh pipelayerjdh is offline
MINI-MOD
Welcome to the ORG.!
Old 03-01-2008, 06:35 AM
AJF AJF is offline
to the org
Old 03-01-2008, 08:09 AM
strokin_early_99 strokin_early_99 is offline
John Wood Nut Swinger
Howdy and welcome to the .ORG. And more importantly welcome to the world of the best diesel engine built, period.
Keep Strokin'
