Door ajar - Ford Powerstroke Diesel Forum
post #1 of 6 Old 05-11-2013, 03:43 PM Thread Starter
t-ray-4ray's Avatar
Quoted: 89 Post(s)
Door ajar
Has anyone had a issue with the door ajar light staying on
Sent from AutoGuide.com App
2000 f-350 4x4 extended cab, went from a flatbed work truck to what you see now, all done by me. Early 99 engine, billet low stall converter, rebuilt trans, all new uvch, new belt tensioners and idler pulley, rebuilt injectors, all new icp, idm, cps, hutch mod, k&n intake, white valve covers, wicked wheel, 5 inch exhaust, php hydra chip 15pos, 8" superlift, 20 inch black and machined rims, 2" billet spacers, 37/13.50r20 toyo open country tires, rough country dual stabilizer, 05 front end with 10k hid lights, amber led cab lights, 09 ford van bucket seats, 2010 f150 center console, b&m ratchet shifter, aero force scan gauge, b&m trans cooler used as a fuel cooler,
t-ray-4ray is offline
post #2 of 6 Old 05-11-2013, 04:21 PM
jaysshortbus's Avatar
My short bus does this occasionally take wd 40 or any spray lube and the metal piece that slides in and out of body right between hinges put straw in and lube it up this usually fixes mine !!
Jay
jaysshortbus is offline
post #3 of 6 Old 05-11-2013, 05:50 PM Thread Starter
t-ray-4ray's Avatar
Quoted: 89 Post(s)
Thanks I will try that in the morning
post #4 of 6 Old 05-12-2013, 12:43 PM Thread Starter
t-ray-4ray's Avatar
Quoted: 89 Post(s)
Couldn't find my wd 40 so I sprayed some tire shine in them and it worked
post #5 of 6 Old 05-12-2013, 12:48 PM
Sweet I think the sensor must b in there is the only thing I could think !! Glad it worked 4 u !!
Jay
post #6 of 6 Old 05-12-2013, 02:26 PM Thread Starter
t-ray-4ray's Avatar
Quoted: 89 Post(s)
Chalk another fix up on my truck thanks to Powerstroke.org my truck has came a long ways in the past two years .
