Weird Noise Sounds like something in the transmission - Ford Powerstroke Diesel Forum
post #1 of 10 Old 05-10-2013, 03:45 PM Thread Starter
Btheman's Avatar
About a month ago I started to get this weird noise. Like a slipping, grinding noise. I first noticed it when I was at a stop and turning right. Push on the fuel peddle and turn right and once I was out of the turn it would stop. Well now, it will do it once in a while from any stop. I have about 216 k on my 1999 F250 PS 4X4 crewcab. I bought it used. I'm faithful about changing the oil, but have yet to change the tranny fluid. I have crawled underneath and check the all the u-joints and anything that I could see just with my eyes. Guess my question is would it be my tranny and what would it be if it was my tranny?
Early 1999 F250 7.3 PSD Automatic
Crewcab - Short Bed
DIY Intake ( Ordering the Tymar)
Btheman is offline
post #2 of 10 Old 05-10-2013, 04:07 PM
Fordgirl89's Avatar
Does it make the noise while you're just sitting there idling? If so I would think broken flexplate.
'99 F350 xlt eclb srw auto 7.3 4x4: S&B, 4" Flowmaster, A-pillar gauges, TS 6position w/ PHP, HPx, Wicked Wheel, 33" Destination M/Ts*2011 MATPA Street Diesel champion!
'95 F250 xlt rc srw auto 7.3 4x4:260cc inj, K&N, A-pillar gauges, fass, T-500, BD modded turbo, Boost fooler, TS 6position, modded IDM, traction bars, 35" Fierce Attitudes, 8" mitre cut, D60
'02 F250 lariat ecsb srw 6-speed 7.3 4x4
Fordgirl89 is offline
post #3 of 10 Old 05-10-2013, 05:35 PM
I also have a noise mine is like a rattle like a heat shield or a bad bearing I think mind is the tq converter .... I've researched the broken flex plates and I took off my inspection plate and you could see the flex plate wobbling while running. You can hear it while its idling once you hit about 1800 is goes away but comes back right after but it's quieter or harder to hear cuz the engine noise... Maybe we have the same problem just sharing my experience!! I got a cleaned used flex plate but I'm doing a tq con to why I'm in there lol
2kStrokr is offline
post #4 of 10 Old 05-11-2013, 09:04 AM Thread Starter
Btheman's Avatar
No it does not do it at a idle. I notice it the most when I'm making a right hand turn from a stop. Even if I let off the throttle in the turn then push on it again it will still do it until I'm rolling.
Crewcab - Short Bed
Btheman is offline
post #5 of 10 Old 05-11-2013, 10:43 AM
Hmmm doesn't sound like turning right has anything to do with it... Maybe the diff? The clutches could be going bad and it does work off torque when throttle applies they will start to grip I think that's how it works I just don't k ow how turning right has anything to do with the tranny
2kStrokr is offline
post #6 of 10 Old 05-11-2013, 11:35 AM Thread Starter
Btheman's Avatar
That might make sense. Maybe its not a turning right thing, but the torque that it takes to get going and with it having to work a little harder when turning. I don't know. Its starting to worry me. I want to fix it before it gets worse.
Crewcab - Short Bed
Btheman is offline
post #7 of 10 Old 05-11-2013, 12:43 PM
Quoted: 5 Post(s)
Wheel Bearings Good?
You might jack it up and check the wheel bearings for any slop or play.
Also, does it make any difference if the hubs are locked or not?
For what its worth, my truck had no issues going straight when my unit bearings started to go out, but made a dull "growling" sound when turning (left or right) - new bearings (and ball joints in my case) solved that problem.
Early 99 F250
DP Tuner F6 Tunes/Autometer Gauges
4R100 Brian's Truck Shop Tranny/6.0 cooler
Kitty Delete
Walker BTM
285 75 R16 Cooper ST-Max Stancor Relay
HPOP Crossover Line, 203F Thermostat, Cold Weather Mods,
Wheel bearings updated to Late 99-03
-58F, 270k+ miles and still Powerstroke (7.3)Loyal
AlaskanEngineer is offline
post #8 of 10 Old 05-11-2013, 12:58 PM Thread Starter
Btheman's Avatar
Good idea...... That is what mine is a dull growling, grinding noise. That might make sense. When I turn right it would be pulling that right rear wheel out so would make that sound. Thanks AlaskenEngineer.
Crewcab - Short Bed
Btheman is offline
post #9 of 10 Old 05-21-2013, 01:32 PM Thread Starter
Btheman's Avatar
So I think I have narrowed it down. I'm going to replace both rear bearings and seals. Would anyone suggest anything else that I should do while I'm in there?
Crewcab - Short Bed
Btheman is offline
post #10 of 10 Old 05-21-2013, 02:39 PM
blue99stroker's Avatar
Quoted: 249 Post(s)
lube the slip joint on the rear driveshaft. they are known to cause slippage in the drivetrain. its easy takes like 15-20 mins while your down there.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
