death wobble? need to know what to fix - Ford Powerstroke Diesel Forum
post #1 of 12 Old 05-10-2013, 08:46 AM Thread Starter
so some people tell me i have a death wobble, but when i see videos it doesnt look like what i have. when i get up to about 35-45 cruising the steering will shake and go from side to side and its pretty bumpy, any other speed it doesnt happen, like i was crusing at about 65 for 10 minutes the other day and it was a normal ride. another friend said i need new rotors and brakes which is probably right anyway, another person said its my hubs, and another person said the tires need to be rebalanced (because i bought them used and never balanced them)
2000 f250
160,000
6inch pro comp lift
35 in mickeys t's
10K HIDís
boost fooler
6 pos chip PHP tunes
4inch straight pipe, dumped
gauges- boost, trans temp, egt
DIY afe intake
Foil Delete
BD thruster turbo
bloom7.3 is offline
post #2 of 12 Old 05-10-2013, 08:50 AM
2000-7.3L's Avatar
Feedback Score: 10 reviews
try getting the tires balenced first!
2000-7.3L is offline
post #3 of 12 Old 05-10-2013, 08:51 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Generally our trucks dont get death wobble because we still have the leafs up front unlike the 05+ with IFS. most likely its either your rotors you may have warped them in a hard brake situation or the used tires. I would try rebalancing the tires first to see if that fixes it then next do brakes then after that then look into other causes
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #4 of 12 Old 05-10-2013, 08:54 AM
2000-7.3L's Avatar
steering damper?
post #5 of 12 Old 05-10-2013, 09:00 AM
Chapter Director
Quoted: 5 Post(s)
Originally Posted by 2000-7.3L View Post
steering damper?
Nope nope nope nope. Steering stabilizers are bandaid covering the problem. the money you spend on the stabilizer can be used to FIX the problem. I have 13 in lift with 44s and i dont run a stabilizer because its not necessary. I may put one on but thats only because i get gnarly bump steer on our sh!tty iowa roads but not for death wobble
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #6 of 12 Old 05-10-2013, 09:36 AM Thread Starter
I have a new stabilizer, only one, don't like the look of two. I bought it like 4 months ago. I'm thinking about doing rebalance then brakes and rotors if that doesn't work.
2000 f250
160,000
6inch pro comp lift
35 in mickeys t's
10K HID’s
boost fooler
DIY afe intake
Foil Delete
BD thruster turbo
bloom7.3 is offline
post #7 of 12 Old 05-10-2013, 10:19 AM
floorboy's Avatar
Tire may have broken a cord. I had one once. Balanced fine, ride like a bucking bronco.
Originally Posted by bjs505 View Post
Of course I'm handy under the hood, I currently own a cummins.
2010 F350 CCLB Cabelas Edition
No Limit cai, Mini Maxx, 5" turbo back Flo Pro, Sinister egr delete, Sinister coolant filter, Cat EC-1, PTP shift solenoid. 20x9 +18 XD Monsters
01' 7.3 CCLB, 6637,wicked wheel G2, HPX, PHP Hydra, MBRP 4" Turbo back, Bellowed uppipes, Stancor gpr, 6.0 cooler, Fpr, Glow shift exhaust, pyro, trans, 203*/billet housing/ Cat EC-1, '07headlights/05' grill, Oh8' gate.
78' F350 "dumpy" old school
floorboy is offline
post #8 of 12 Old 05-10-2013, 10:40 AM
russtwentyfour's Avatar
When you get it rebalanced check and make sure all your steering linkage and ball joints don't have free play. Easy to do while front ends off the ground.
E99 F350 Ext. cab Long bed, single wheel 2x4
Riff Raff 6637 intake, FRX and HPX,
Dieselsite boostfooler, factory tech valvebody, filter system,
Local custom trans build - BTS in near future,
Derale cooling pan and trans cooler,
Mbrp 4" turbo back
Ts 6 pos chip - TW tunes coming soon,
Guzzles hutch and harpoon mod with lift pump and racor filters
Ww2
Blank pedestal with moded exhaust port
Afe rear end cover
Callahan drilled and slotted rotors front and rear
russtwentyfour is offline
post #9 of 12 Old 05-10-2013, 11:04 AM Thread Starter
Floorboy. What's a broken cord?
2000 f250
160,000
6inch pro comp lift
35 in mickeys t's
10K HID’s
boost fooler
DIY afe intake
Foil Delete
BD thruster turbo
bloom7.3 is offline
post #10 of 12 Old 05-10-2013, 12:08 PM
Quoted: 17 Post(s)
There are a lot of causes for death wobble. But like Rammstein said is more rare on leaf springs. It can be caused by bad ball joints(not just in the knuckles or C's either)ball joints in your steering, loose track bar, unbalanced tires, worn hubs, unbalanced rotors, worn leaf/shackle bushings (make it more noticeable) sloppy/ bad steering box, bad alignment. Just to name a few. If it happens to be your hub/unit bearings be sure to buy quality ones with Timken bearings preferred. Otherwise you could be changing it in 2 weeks.
Almost forgot, if your steering stabilizer leaked out its fluid it won't help at all, I have had it make DW worse. (Been there & done that)
2000 Ford Excursion Limited 4x4 Diesel
2007 Jeep Wrangler unlimited on 1 tons & with 41.5" Pitbull Rockers
TBJK is offline
