2000 7.3L dully white smoke and dlc problems - Ford Powerstroke Diesel Forum
post #1 of 12 Old 05-10-2013, 07:52 AM Thread Starter
ok first time user. in my shop iv got this truck it came in cuz of rough idle and once it warmed up it started blowing white smoke and smelled like raw diesel. i went to pull codes on it and and my reader turns on but then says could not connect. i checked fuse number 3(20amp) with a test light and it has power and is not blown and sence the code reader is powering up the dlc has power. can anyone help me with this problem?
lucio10288 is offline
post #2 of 12 Old 05-10-2013, 08:17 AM
rascal's Avatar
PCM gone bad? Got one you can swap to try it out?
good luck
Rascal
2000 F-350 XLT ECSB ZF6 4x4
38R+WW | Adrenaline HPOP | Optima | Ravelco | Mag Hytecs | Dynatrac | EBC | Strictly Diesel | AFE | Magnaflow | ISSPRO | DieselSite
rascal is offline
post #3 of 12 Old 05-10-2013, 08:21 AM Thread Starter
no i dont. im trying to talk the boss into geting one. will replacing the pcm fix the white smoke and rough idle problem?
post #4 of 12 Old 05-10-2013, 08:27 AM
rascal's Avatar
Well, it is the Powertrain Control Module. I was trying to address more of the issue connecting your scanner and I was thinking along the lines the issues are probably all connected. Is the truck chipped? If so, remove it and see what happens.
Rough idle could be the engine harness connection at the valve covers where it connects to the UVCH. They are notorious for coming loose and causing rough idle issues.
Good luck.
Rascal
rascal is offline
post #5 of 12 Old 05-10-2013, 08:29 AM Thread Starter
no its not chipped.ok ill check the conections. and come back if i find anything.
post #6 of 12 Old 05-10-2013, 09:24 AM Thread Starter
ok the conectors are good under the valve covers.
post #7 of 12 Old 05-10-2013, 10:21 AM
floorboy's Avatar
You checked under both valve covers in 55 minutes?? Wow.
Originally Posted by bjs505 View Post
Of course I'm handy under the hood, I currently own a cummins.
2010 F350 CCLB Cabelas Edition
No Limit cai, Mini Maxx, 5" turbo back Flo Pro, Sinister egr delete, Sinister coolant filter, Cat EC-1, PTP shift solenoid. 20x9 +18 XD Monsters
01' 7.3 CCLB, 6637,wicked wheel G2, HPX, PHP Hydra, MBRP 4" Turbo back, Bellowed uppipes, Stancor gpr, 6.0 cooler, Fpr, Glow shift exhaust, pyro, trans, 203*/billet housing/ Cat EC-1, '07headlights/05' grill, Oh8' gate.
78' F350 "dumpy" old school
floorboy is offline
post #8 of 12 Old 05-10-2013, 10:25 AM Thread Starter
ok so i cranked it up and its blowing a bulish whiteish smoke out of the tail pipe.
post #9 of 12 Old 05-10-2013, 10:26 AM Thread Starter
i had most of it already broken down
post #10 of 12 Old 05-10-2013, 11:43 AM Thread Starter
anyone with more advice?
Tags
2000 f350 7.3 diesel , blue smoke , dlc conection problems , white smoke
