5V-12V Power source? - Ford Powerstroke Diesel Forum
post #1 of 13 Old 05-10-2013, 05:47 AM Thread Starter
codyryan07's Avatar
Hey guys, I'm looking for a power source to work with a 'carputer' i'm building.. I have the controller to handle start ups and shut downs, but I need to tie into a power source that comes on with the key, and stays on through cranking then shuts off once the key is off..
Everything I've found kills power when being cranked, which in my case, would kill my boot up.. soo any ideas?
Cody Ryan
03 f250 ccsb fx4 7.3
4" RC lift
35x12.50 federals on 20x12 rockstars
6637 intake, straight pipe
full RR w/ fuel bowl delete.
rebuild coming soon
codyryan07 is offline
post #2 of 13 Old 05-10-2013, 05:57 AM
ZMANN's Avatar
Quoted: 1668 Post(s)
why don't u use a constant hot and switch it ? then you could use it anytime
truck on or off ?
there is bound to be a few circuits that don't shut off with a key to crank
but I am not sure where ?,, I do believe the OBD port stays energized but keys off
We Miss you Ronnie
ZMANN is online now
post #3 of 13 Old 05-10-2013, 06:17 AM Thread Starter
codyryan07's Avatar
truck on or off ?
I'm looking for something that will come on when I turn the key and am waiting for the WTS light (during that time, computer starts booting), then stay on while I crank.. I looked at the radio, but it shuts off for a brief moment while starting..
I've thought about the switch, but it would be my luck that I would forget to turn it off and next morning I come out to dead batteries..
Maybe I can find a way that when I turn my key on, it triggers a relay and runs off a 12v constant on source, and when power is shut off to that relay, it triggers the hibernate/shut down..
Cody Ryan
4" RC lift
rebuild coming soon
post #4 of 13 Old 05-10-2013, 06:25 AM
You need to wire a latching relay system. I believe there is a wiring diagram over at the12volt.com I would draw one if I wasn't on my phone.
2006 White F350 CCLB 2WD
dowmace is offline
post #5 of 13 Old 05-10-2013, 06:27 AM
ZMANN's Avatar
well probe the OBD?
and also a lot of years the cig lighter is the same circuit as the OBD power so you can see if it times out upon crank
there are plenty of workarounds for the issue but I am sure you can find a power source to meet your need and keep it simple
We Miss you Ronnie
ZMANN is online now
post #6 of 13 Old 05-10-2013, 06:44 AM Thread Starter
codyryan07's Avatar
Thanks y'all.
I'll look into the latching relay system and look into the OBD port. I'll be using the OBD port after the install because i'll have AE running too, so I can just switch windows and run full diagnostics on the truck.
Cody Ryan
4" RC lift
rebuild coming soon
post #7 of 13 Old 05-10-2013, 07:38 AM
timmyboy76's Avatar
LM7805
https://www.google.com/search?q=LM78...w=1024&bih=629
radio Shack.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #8 of 13 Old 05-10-2013, 08:04 AM
ZMANN's Avatar
remember A/E highly suggest that you do not charge your computer while running diagnostics with the A/E device
they even have pics of a BBQ hardware device
I an not sure this would apply to your method of charging unless your running an inverter but that would be in efficient anyway
We Miss you Ronnie
ZMANN is online now
post #9 of 13 Old 05-10-2013, 08:06 AM
ZMANN's Avatar
Originally Posted by timmyboy76 View Post
how does a regulator keep power during the crank cycle ??
We Miss you Ronnie
ZMANN is online now
post #10 of 13 Old 05-10-2013, 10:26 AM Thread Starter
codyryan07's Avatar
Yeah, I'm not quiet sure where you're getting at with that? maybe a little better explanation..?
I wouldn't necessarily be charging, it would be powered to run the computer, like the battery does for a laptop, and a power supply does on the desktop computers.. I don't see how power used to run the computer system would fry anything while using AE.
The micro-ITX board i'm using is a low power consumption board, which is why its able to run off of 5v-12v..
I haven't found anything done on a superduty diesel, so it's hard to say what exactly will happen, although i've found a lot of build info for cars..
Cody Ryan
4" RC lift
rebuild coming soon
