Really needing help with axle shaft install - Ford Powerstroke Diesel Forum
post #1 of 6 Old 05-10-2013, 05:20 AM Thread Starter
LEARNING AS I GO
bck4more's Avatar
OK so i decided to replace and redo my front end with replacing tie rods, ball joints and hubs and so on. Well here is my issue i put new axle shaft seals on both sides but now i cant get the lock ring (inside of hub on shaft) to fall back into the groove on the shaft. I installed spindle-shaft-thrush ring-hub-3 washers then that's where the lock ring is suppose to go but the groove is to far back. Now if i removed one of the washers then it would probably fit but not really wanting to do that. I've pried like theirs no tomorrow on the shaft to get it to move out more but no luck as of yet. Can i get some help here guys thanks
1999 Ford F-250 Crew Cab Lariat 4x4 7.3L Powerstroke zf 6-speed Planet colors Amber White Pearl
banks big head wastegate, edge ez module
snow performance, 4" stright pipe,6637 FILTER MOD southbend stage 2 clutch, 05' front end upgrade
8" procomp 37" M16 Swampers 18x9 xd monsters, MOOG everything BILSTEIN SHOCKS BILSTEIN DUAL STEERING STABILIZER COOLANT FILTRATION, 203 stat 08' mirrors
bck4more is offline
post #2 of 6 Old 05-10-2013, 06:08 AM
Quoted: 176 Post(s)
Feedback Score: 3 reviews
By axle seals, do you mean the Big, Metal, Knuckle Seals in the Hub? If so, what did you drive them in with? They need a tool you can borrow/rent/make to get them in straight without damage. It sounds like they're not in right maybe... If not driven into the hub far enough you can have this trouble.
I'm with you, leaving one of the washers out is not a good option
NoRalPh is offline
post #3 of 6 Old 05-10-2013, 06:15 AM
ZMANN's Avatar
Quoted: 1781 Post(s)
Welcome to guzzle's 4x4 Needle Bearing Maintenance Web Page
Welcome to guzzle's 4x4 Autolock Hub Lubrication Maintenance Web Page
from guzzles 2002
I am also curious if you did the knuckle seal ?
We Miss you Ronnie
ZMANN is offline
post #4 of 6 Old 05-11-2013, 02:15 AM
i just did all my ball joints and rod ends yesterday, same thing happened to me. i installed the seals with the homemade installer made from pipe and flanges from lowes. it worked fine. the passenger side did the same thing, the snap ring groove was the to far inboard to engage the ring. used a big pry bar on the universal to extend the shaft out a bit and push the ring into the groove with a screwdriver. the short side was the same way although was much harder to get it to push out but got it.
good luck!
spoonsc1 is offline
post #5 of 6 Old 05-11-2013, 03:59 AM
Term3's Avatar
Quoted: 2 Post(s)
Axle seal video
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #6 of 6 Old 05-11-2013, 05:59 AM
Quoted: 176 Post(s)
Originally Posted by Term3 View Post
Axle seal video
For a truck other than his...
NoRalPh is offline
