Used 7.3 Install - Ford Powerstroke Diesel Forum
post #1 of 18 Old 05-09-2013, 08:01 PM Thread Starter
Used 7.3 Install
Alright fellas, not sure if any of you remember me from a while back, but the old (not nearly old enough) 7.3 has finally taken a crap. So it's safe to say I'm done with that motor and will be putting a used motor in.
I have found a used 7.3 at a junk yard about 30 miles from me. It's $3150+$200 core. I went to check it out today and it seems fairly solid. It's in a 2002 F250 that had 60k on the clock before it was rolled back in January. I ran a carfax on the VIN and it's a 2 owner vehicle. The most recent owner only put about 4500 miles/year for the past 7 years. It was serviced once back at 11k, but there's no record of it being in a shop after that. There is some oil filming going on up top, but that's to be suspected due to the stock intake boots. I didn't see any oil pooling up in the valley and it seems pretty dry. The oil pan is COMPLETELY dry and no sign that there was ever any oil on it. What bothers me just a tad though is that there is some oil on the bottom of the transmission and a little cake up under the HPOP. The junk yard says once it's paid for they will make sure it starts up and put it through a multi point inspection (necessary to offer the warranty which is $375 for 3 years/30k and covers parts and $65/hr labor). I also told them I would like to see it run and would like to inspect it BEFORE they clean it.
So I guess my question for you guys is what should I look/listen for specifically when checking this thing out? Also, I've always been a believer in the "while-im-at-it" mentality, so what would you guys recommend I do while the shop has the front clip off and the engine bay empty?
2001 F450 Dump, 7.3, 4R100
Mods: Adrenaline HPOP, New Factory HPOP lines, Rebuilt Fuel Bowl, International Bellowed Up Pipes, CCV mod, Deisel Site Intercooler Boot Kit, New Water Pump, New PS Pump, 203* Therm, New Injector O-Rings, New Oil Cooler and Filter Assembly, Vitin o-rings throughout and a few other things I'm sure I forgot to mention
CCA-F450 is offline
post #2 of 18 Old 05-10-2013, 06:54 AM Thread Starter
Here are some quick photos I snapped.
CCA-F450 is offline
post #3 of 18 Old 05-10-2013, 11:22 AM
Seth14's Avatar
Just a thought, but I bought a long block from blackwater engines with arp head studs, 910 comp valve springs, forged rods, and stellite valves for $4100, your block just had to be useable.....ie, no cracks or holes. I'm putting about 550+ hp to it now.
Late 99, Blackwater long block, forged rods, ARP studs, 910 comp valve springs, stelite valves, 38R turbo, 238/100 hybrids, TS 6 position chip custom tuned by Beans, T500 hpop, FRx, Airdog 150, S&B intake, side piped, edge insight cts monitor, DC2 rims, Crusher tires, BTS transmission, 6.0 31 row tranny cooler, and lots of blue lights!!!!
Seth14 is offline
post #4 of 18 Old 05-10-2013, 11:23 AM
Seth14's Avatar
I mean your block had to be a useable core.
Seth14 is offline
post #5 of 18 Old 05-10-2013, 11:46 AM
Just my opinion but that motor looks really dirty for 60,000 mi. I have 196,000 miles on mine and it's not nearly that dirty; and I am not one to clean the engine compartment. Personally that would scare me away but I am pretty picky.
2014 F150 SCREW XLT 4x4 Ecoboost.
blderman is offline
post #6 of 18 Old 05-10-2013, 02:42 PM
I second the dirtiness. From the looks of that front axle it looks like the truck has been mudded a few times.
208 F250 6.4 Lariat
4" Downpipe Back, AFE Dry Intake, EGR Block Plates, SCT Livewire TS with PIP tuning, 2.5" Level, 35 Toyo M/T
----SOLD---
2003 F250 7.3 XLT
6637, 4" Exhaust, 50 hp tune, Irate Regulated Return, HPx, Bellowed Up-Pipes, Boost Trans and EGT Gauges, 2.5" Level Kit, Sky Jacker Dual Stabilizers, 305/70r16 Fierce Attitude M/T
Nolooseends is offline
post #7 of 18 Old 05-10-2013, 04:32 PM
codyryan07's Avatar
what part of the block "took a crap"?? The reason I ask is because I just had a block machined and matching pistons for about $750 (may be less, depending on what you throw at it..) most engine shops will freshen up heads for about $250-300.. I just think you could have a fresh rebuilt block for MUCH less than the junkyard motor you know nothing about.. Just reuse your accessories.. IIRC, if worse case scenarios, the blocks can be sleeved too..
my .02 cents..
Cody Ryan
03 f250 ccsb fx4 7.3
4" RC lift
35x12.50 federals on 20x12 rockstars
6637 intake, straight pipe
full RR w/ fuel bowl delete.
rebuild coming soon
codyryan07 is offline
post #8 of 18 Old 05-10-2013, 04:54 PM
nohsp4u's Avatar
I am the farthest away from being a mechanic, but i would have to say the same. That engine is dirty. It may be sitting around and dust collecting on old wet spots but, $3k+? when my day comes, i would prefer to rebuild and know what i have rather than depend on joe and chuck and the local Junk for an engine.
1997 F-350 XLT Lariat Crewcab long box 4x4. Oxford white with an ugly green. 133xxx miles. Hide away goose neck, banks turbo, exhaust, inner cooler, intake filter and gauges.
nohsp4u is offline
post #9 of 18 Old 05-13-2013, 01:05 PM Thread Starter
Yeah, the dirt/grime does kinda scare me. I'm hoping the mud came from when it flipped over. The previous owner (2nd) only put about 4500 miles/year on it and it has a total of 71k on the clock. All the other ones I found had 150k-200k and didn't offer the 3 year warranty.
I literally have ZERO faith in the motor that is in the dump truck right now. I'm 100% sure it was never maintained. I have a feeling there is a bent rod and possibly a hole in the block somewhere. It's really tight when turning with a breaker bar even with the glow plugs out and there was rust underneath the valve covers.
I went to the junk yard today and got them to start it up. It took a second to start, sounded good for a little, but then it got a little wonky after he revved it a bit (end of the video).
CCA-F450 is offline
post #10 of 18 Old 05-13-2013, 01:21 PM
That motor has issues, I wouldn't touch it for that price. I would have to seriously think about before paying $1,000 even.
blderman is offline
