Will 2012 dually rims fit my 99? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 05-09-2013, 10:07 AM Thread Starter
My rims have some of the finish bubbling off and the tires are cracking on sidewalls. Local craigslist ad has set of 2012 dually rims listed.
Will they bolt right up?
I have manual front hubs, will that limit the rims that fit this truck?
JB4XX is offline
post #2 of 10 Old 05-09-2013, 10:32 AM
dannanw's Avatar
Quoted: 65 Post(s)
Garage
diffrent lung pattern I've been told
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #3 of 10 Old 05-09-2013, 01:29 PM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
They will not work, around 2005 or so they changed the bolt pattern from 8 on 170mm to 8 on 200mm.
So you will need wheels from a 99-04 Superduty dually.
2005 F-250 CC/SB 4x4 medium wedgewood blue
5" lift, 5" Donahoe rear springs, 35x13.50 MTZ's, 18x12 Fuel Hostage wheels, 4.30 gears, Banks 4" exhaust, Airraid intake, SCT from Innovative, ARP headstuds, Bulletproof ficm, Bulletproof EGR cooler, Scangauge II, Randy Ellis Design lightbar, Street Scene flares, Harpoon mod, Zoodad mod, LED 2010 taillights, Switchback LED front turn signals
GregsSD is offline
post #4 of 10 Old 05-10-2013, 05:41 AM
Quoted: 27 Post(s)
Dually may be different but i put my dads wheels off his 2011 on my 2000. Only difference was thread pitch. Both single rear wheel. I dont see why ford would go through the trouble of having 2 different lug patterns
CarportMechanic is offline
post #5 of 10 Old 05-10-2013, 06:06 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
duallys are different like stated above in 05 they went to 8x200 for duallys instead of 8x170. The reason for would do that...? because they want you to have to buy their wheels and make it harder to buy aftermarket just like they did back in 99 when they went from 8x6.5 to 8x170
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #6 of 10 Old 05-10-2013, 10:05 AM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
And just like they did by coming out with 7 lug wheels before that!
GregsSD is offline
post #7 of 10 Old 05-10-2013, 11:23 AM
Quoted: 17 Post(s)
The 450's from what I remember are 10 lug now too, strange that they would have made 350 dually's diff from 250. I have an 08 SD SRW super 60 in the front of my Jeep & it's 8 on 170 with little over 5" center hole for the locking hubs. Manufactures do some weird chit sometimes.
2000 Ford Excursion Limited 4x4 Diesel
2007 Jeep Wrangler unlimited on 1 tons & with 41.5" Pitbull Rockers
TBJK is offline
post #8 of 10 Old 05-10-2013, 04:59 PM
goats's Avatar
Quoted: 2 Post(s)
05 are the same cause I sold rims off my l99 to a guy with a 06 with no issue. Only thing different was the thread pitch and his was a 250
goats is offline
post #9 of 10 Old 05-10-2013, 05:13 PM
Chapter Director
Quoted: 5 Post(s)
Originally Posted by goats View Post
05 are the same cause I sold rims off my l8er to a guy with a 06 with no issue. Only thing different was the thread pitch and his was a 250
maybe its just on f350s they went to 8x200. i know at some point they went to that
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #10 of 10 Old 05-10-2013, 08:29 PM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
It is only the F-350 dually's that changed to 8x200mm.
The F-250's and SRW F-350's still use 8x170mm.
GregsSD is offline
