can i change tire size without effecting fuel economy? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 05-08-2013, 10:16 PM Thread Starter
I have a 99 with 16s on and have been wondering what sizes can i consider without hurting economy. thought about 17s or 18 but wanted to hear from those who have made the change.
DONE:
EGR delete--4" turbo back exhaust
75HP tune
hotairgypsy is offline
post #2 of 6 Old 05-09-2013, 03:05 AM
MSTR-P's Avatar
So, you are thinking about changing your wheel size, tire size, or both? Any changes you make that add weight to the truck is going to affect your fuel economy. How significant the change depends on how big you go.
'03 7.3 - Stock!
MSTR-P is offline
post #3 of 6 Old 05-09-2013, 03:39 AM
BIG Laing's Avatar
plus if you go wider the extra width will hurt aerodynamics, and add resistance. (Even if the weight and diameter is the same)
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #4 of 6 Old 05-09-2013, 04:09 AM
Zaairman's Avatar
Quoted: 12 Post(s)
You could go up to like a 285/75/16 tire size without hurting fuel economy. Once you get bigger wheels, the wheels weigh more than your stockers.
Zach
2000/2006ish Ford F-250 Larryette 7.3 Powerstroke 4x4
5" Sewer Pipe Exhaust
, DIY 6637 Intake, Wicked Wheel'd, De-foiled, Missing EBPV, Edge Juice with Attitude, Few leaves added here and there, 35" BFGs, 16x10 Eagle Alloys, Alpine W200
SLAPS Member #153
Zaairman is offline
post #5 of 6 Old 05-09-2013, 06:18 AM
dannanw's Avatar
Quoted: 63 Post(s)
Garage
yea....go down in size will help it go up
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #6 of 6 Old 05-09-2013, 11:00 AM
Redlazer's Avatar
With out going with bigger wheels 285x75r16 with 18s wheels 285x65r18. Both should give you better economy by lower gear ratio.
early 99 Red F-250 XL SD, 7.3L, 6-speed manual, Extended Cab, Long Bed, 4x4 Off Road, and Reflexxion Cowl Hood, Ion Alloy 183 wheels, 05 headlights with 6000k AC HID kit, and led turn signals, Ford ASI filter w/ zoodad mod and foam sleeve, TS 6 position chip, Auto Meter Z series Boost and EGT gauges, and straight pipe oem exhaust. .
CAROLINA GRAY BOY
Redlazer is offline
