Need international Part # for hpop lines - Ford Powerstroke Diesel Forum
post #1 of 5 Old 05-08-2013, 06:19 PM Thread Starter
Eco Taxi's Avatar
I have a 01 F350 7.3
I am replacing both of my hpop lines that go from the hpop to each side
I stumbled across a thread that had the ford part #s for these lines but also the international part # for the drivers side line
The individual who gave this international part number said the international part was exactly the same and it was atleast $20 cheaper
I can confirm it being cheaper for that part - I was not able to come across an international part # for the pass side line
so far this is what i have
hpop hose 1999-2003 drivers side
ford part # YC3Z9J323E & International part # 1831420C91
hpop hose 1999-2001 passenger's side
ford part # F81Z9J323E
Can anyone confirm I have the correct ford part numbers and then also give insight on the international aspect of this
also when changing the hpop lines i have a diagram break down im looking at and it shows there is a separate "connection" part - part # 1826744C1 that goes to the engine block and a different connection part number (part # 1825956C1) for the beginning of the hpop line where it meets the hpop
^do you changes those connections and then the corresponding o-ring when you change the line?
Thanks in advance
Kyle
2001 F350 Chassis Cab 4x4 DRW Flatbed 130k miles+
Quad Gauge Pillar - Aeroforce Interceptor & Glowshift Series 7 EGT, Boost, Trans Temp
Foil Delete | Marinco Mod | High Torque 4kw Starter | Door Seal Mod | AIH Delete | Coolant Filter & 203* Thermostat w/ Billet Aluminum Housing | Hutch Mod | RiffRaff Fpx, Hpx, boots | WW2 | Deleted ebpv
“The good thing about science is that it's true whether or not you believe in it.” ― Neil deGrasse Tyson
Eco Taxi is offline
post #2 of 5 Old 05-08-2013, 07:44 PM
russtwentyfour's Avatar
Found this info on another site
Ford Part # YC3Z9J323DA Intl Part #1827889C91 HOSE ASY-HIGH PRESS RH
Ford Part # YC3Z9J323E Intl Part #1831420C91 HOSE ASY-HIGH PRESS LH
Part number YC3Z9J323BA was superseded by part number YC3Z9J323E.
Here's a link to the info I found, HPOP hose part #'s? - Ford Truck Enthusiasts Forums
Why not go to DieselOrings and get both hoses and necessary orings with removal tool all at one place and good parts also.
Hope this helps you out
E99 F350 Ext. cab Long bed, single wheel 2x4
Riff Raff 6637 intake, FRX and HPX,
Dieselsite boostfooler, factory tech valvebody, filter system,
Local custom trans build - BTS in near future,
Derale cooling pan and trans cooler,
Mbrp 4" turbo back
Ts 6 pos chip - TW tunes coming soon,
Guzzles hutch and harpoon mod with lift pump and racor filters
Ww2
Blank pedestal with moded exhaust port
Afe rear end cover
Callahan drilled and slotted rotors front and rear
russtwentyfour is offline
post #3 of 5 Old 05-08-2013, 08:17 PM Thread Starter
Eco Taxi's Avatar
I did not know of Dieselorings. Exactly what I'm looking for. Thanks for the response
Kyle
Eco Taxi is offline
post #4 of 5 Old 05-08-2013, 08:38 PM
Hose release tool:
#8-6595 HPOP Hose Quick Release Tool - High Pressure Oil Pump - 1999-2003 Ford 7.3L
Passenger side hose:
DieselOirngs: High Pressure Oil Pump HOSE - Right side (passenger) for the 1999 1/2-2003 7.3L
Drivers side hose:
DieselOrings: High Pressure Oil Pump HOSE - Left side (driver's side) for the 1999-2003 7.3L
Oring kit for hose on hpop side, you'll need 2:
HPOP Quick Disconnect Hose Fitting Repair Kit 1999 - 2003
Oring kit for hose on head end, you'll also need 2 of these:
DieselOrings: HPOP Cylinder Head Quick Disconnect Hose Fitting Repair Kit 1999 - 2003 7.3L
They have just about every seal or oring you could possibly need ever, are very quick to ship and have been great to me.
Mbrp 4" turbo back
Ww2
Afe rear end cover
post #5 of 5 Old 05-09-2013, 01:37 PM
blue99stroker's Avatar
Quoted: 283 Post(s)
or check riffraff they carry all of the stuff too.
both shops are great.
99.5 f250 7.3 4x4 265k Full Force 160/30, PHP Hydra, S&B CAI, 4" Exhaust, Van Turbo, RR 6/6 Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool Max.
Dad-2000 F250 7.3 4x4 114k Autometer Gauges, Superchips 1705 (Tow Safe), Blue 6637, 4" Exhaust, BD Billet Wheel, Trucool Max.
blue99stroker is offline
