2000 7.3L just shuts down - Ford Powerstroke Diesel Forum
post #1 of 5 Old 05-07-2013, 09:58 AM Thread Starter
I have a 2000 7.3L every once in a while it just dies thought it was the cam censor at first but replaced that and it still does it. Usually it dies at idle but the other day I got into it as i pulled out in traffic and it died but then took off like it ran out of fuel. Sometimes it will not want to start but if you cycle the fuel pump a few times it will start(maybe a coincidence?). Any suggestions? The truck has 4" mbrp exhaust, afe cold air intake, and a 6 position tuner that i am not sure what it is but i keep it on the low settings to be safe figured i would have it reprogrammed after i get injectors and fuel system.
BOBBY57 is offline
post #2 of 5 Old 05-07-2013, 10:15 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Your fuel pump is probably going bad. Go cycle the key and see if u can hear the fuel pump buzz everytime you cycle.
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #3 of 5 Old 05-07-2013, 10:23 AM Thread Starter
I have cycled it several times and it does buzz everytime i cycle it. I saw somewhere about the tanks delaminating is that true should I check the inside of tank and i was thinking about a complete new fuel system and injectors nothing crazy just enough to get better fuel mileage and a little more power so i can outrun my buddies duramax that is stock with an edge tuner.
BOBBY57 is offline
post #4 of 5 Old 05-07-2013, 10:25 AM Thread Starter
My buddy works at ford and said that he and a few other guys were putting the ford lightning valve body in there tranny's because they were built stronger for performance any truth to that?
BOBBY57 is offline
post #5 of 5 Old 05-07-2013, 10:35 AM
Chapter Director
Quoted: 5 Post(s)
Hmm i have never heard of tanks delaminating but i suppose its possible. maybe you have sediment buildup right where the fuel pump sucks up and depending on where and how you park and drive its clogging
No idea on that either, id imagine a super duty is the best parts you can get but maybe the ford lightning being a speed truck it has a better one. worth looking into. someone else should chime in with more info
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
