Ihc 7.3l as a spare engine - Ford Powerstroke Diesel Forum
post #1 of 3 Old 05-06-2013, 08:04 PM Thread Starter
New here and I have a question. Our maint shop has 2 freshly rebuilt international 7.3l mechanical pump motors just sitting here. One is a basic block/heads/intake but the other is complete with fuel pump injectors and at190 garrett turbo. I have a 2000 PSD CC 6 speed that I'm gonna keep till the wheels fall off. Just wondering if I should try to snag one and maybe use it down the road. Fact is I don't know how much will cross over. (HPOP vs mechanical pump/injectors/different heads) Should I try to get one and put it away for a rainy day??? Are they worth anything performance wise? I can get both pretty cheap.
Thanks
Dan
Doodad is offline
post #2 of 3 Old 05-06-2013, 10:57 PM
JSchuricht's Avatar
If those are pre 94 IDI motors then nothing will cross over to your truck.
JSchuricht is offline
post #3 of 3 Old 05-08-2013, 12:55 PM
Im_Strokin_ur_Cummins's Avatar
Location: Lowville, New York. Studying Mechanical Eng. @ Suny Canton
I'd grab one if I where you if you dont want it someone else will! Alot of people are looking for the 7.3 engines.
FUELED BY HATERS
Jack'em up high.Fat chicks cant jump!
E99 7.3 F-250XLT
304,345 miles and still running strong
ext cab
DIY 6637 Intake
5in straight pipe to Aussie stacks
PHP 6pos
Boost,tran,and EGT Gauges
4in lift
Some body rust and oil leaks
CB radio
Pretty Girl sittin next to me
Im_Strokin_ur_Cummins is offline
