obs running gear under my SD? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 05-06-2013, 07:31 AM Thread Starter
shortstrokin's Avatar
I have a 2000 f250 2wd srw. I recently purchased a 96 f350 2wd dually and was thinking about putting the dually running gear (front and rear) under my 250. Is this possible? I would like to make mine a shortbed dually but the conversion parts for SD trucks seems to be extremely expensive in the area.
shortstrokin is offline
post #2 of 3 Old 05-07-2013, 12:09 AM
JSchuricht's Avatar
Anything is possable but not everything you can do is wise. You would loose your front ABS, downgrade the rotor/pad size and downgrade the rear from disk to drum. All you really need to do is find a 99-04 DRW axle for a pickup and the spacers for the front. Driveshaft might be different too, the DRW axle is a D80, your using a Sterling 10.5, the OBS uses a Sterling 10.25 for both SRW and DRW.
JSchuricht is offline
post #3 of 3 Old 05-07-2013, 04:30 AM Thread Starter
That us exactly the type of info I was looking for. Thank you very much.
