Pulling my motor - Ford Powerstroke Diesel Forum
post #1 of 8 Old 05-05-2013, 11:59 PM Thread Starter
Mylucky24's Avatar
Pulling my motor
So I have a few nasty oil leaks on my 02 f350 7.3 auto.... I found a ford diesel mechanic that will pull my motor for 500 bucks. The other day he showed me a parts list that he came up with for the tune of 250$. Seems reasonable. That was with all the seals for the motor I believe. The motor only has 104,xxx miles. Is there anything else I should replace while the motor is out?
Sent from AutoGuide.com App
Mylucky24 is offline
post #2 of 8 Old 05-06-2013, 04:00 AM
Quoted: 16 Post(s)
Feedback Score: 3 reviews
Up pipes. Check oil pan
2000 F250 XcabSB, 4x4, 4" strait pipe, DIY intake, FRx, BDP tunes, WW2, 6.0 cooler, BTS VB, gauges, 55w digital projector HIDs
gomer pyle is offline
post #3 of 8 Old 05-06-2013, 10:35 AM
Justin@DP-Tuner's Avatar
Quoted: 50 Post(s)
No need to pull the motor to repair the oil leaks if they are coming from in the valley. Now if it is the pan, that is another story.
So what exactly is leaking? There should not be that much at only 104,000 miles.
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
post #4 of 8 Old 05-06-2013, 10:40 AM
JD3020's Avatar
I yanked the engine out of my OBS a couple months ago, and just got it back up and running a few weeks ago. I think i had over $250 in seals/gaskets, and something like $600 total in parts, not counting the $700 i spent for an engine. But the only things i didn't touch were the headgaskets and rear main, and i replaced some stock parts with aftermarket stuff.
Jimmy
97 F-250 ECLB 7.3/E4OD/4wd, 216k miles: FFD 250/200%'s, stock turbo, built trans, e-fuel, Swamps IDM, shimmed 910's, Melling LPOP, welded cam gear/modified pick-up tube. Built and tuned by me
97 F-250 ECSB project truck:250/2's, Gen 3, S468, SD axles, studs/springs, ZF-6
JD3020 is offline
post #5 of 8 Old 05-06-2013, 10:42 AM
Galaxie's Avatar
I wouldn't jump the gun on this. Dig into your leaks before you pull the motor.
1. Dont need to pull it for your leaks unless your pan is rusty
2. Even if $500 is a lot to you, you might stir up other issues by pulling
3. At that low of miles, more than likely its something else
For example, my 7.3 had the PCV stick. Turned everything into an oil bath. The $5 part that failed made the turbo boots leak all over the place then the oil traveled around the motor looking like other stuff was leaking bad.
Fixed it, cleaned it, all good!
Colin
59-68Galaxies, Fairlanes
54 Ford Skyliner Glass Top
60 Country Sedan Wagon
87/93 5.0s 347
Buy/Sell/Trade/Service 40s50s60s cars!
06 F350 Dark Stone XLT FX4
SCTX3 Custom Tunes
ARP Head Studs
EGR Cooler gone
MBRP Stright Pipe
Edge Insight
20" Harleys 35" AT2
2011 Tailgate
Eaton TrueTrac
2" Leveling
Black Windows/lights
Blue Spring
03 Turbo
Galaxie is offline
post #6 of 8 Old 05-06-2013, 10:43 AM Thread Starter
Mylucky24's Avatar
The pan is leaking. After buying the truck I realized they had cut the crossmember out of the truck replace the oil pan I believe. They welded the crossmember back in and it was done very well however they used just regular rtv to seal it back up. 👎
post #7 of 8 Old 05-06-2013, 10:52 AM Thread Starter
Mylucky24's Avatar
I've had a few different shops look at it. I know for sure the oil pan, valve covers, oil cooler, and the dip stick on the side of the pan are all leaking.
post #8 of 8 Old 05-06-2013, 03:01 PM
Galaxie's Avatar
Yea, the pan is the big issue!
Colin
87/93 5.0s 347
SCTX3 Custom Tunes
ARP Head Studs
EGR Cooler gone
MBRP Stright Pipe
Edge Insight
20" Harleys 35" AT2
2011 Tailgate
Eaton TrueTrac
2" Leveling
Blue Spring
03 Turbo
Galaxie is offline
