boost problem - Ford Powerstroke Diesel Forum
post #1 of 7 Old 05-05-2013, 06:05 PM Thread Starter
boost problem
Have a 2002 7.3. Had to put a new remanufactured engine from ford. Runs great on the road but the minute you step on it the boost is lost and blowback smoke. Been ford for a week reticent seem to find the problem any suggestions
rossronald is offline
post #2 of 7 Old 05-05-2013, 07:30 PM
Joel's Avatar
Quoted: 10 Post(s)
Bad turbo, Super dirty air filter, bad boost leak, EBPV stuck closed, the list is pretty endless until some stuff is ruled out
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #3 of 7 Old 05-06-2013, 05:58 AM Thread Starter
boost problem
Ford put a new turbo on didn't change problem. Has a K&N filter that was dirty cleaned it and started working but soon went right back to no boost ford techs can't even come up with a solution motor has about 1200 miles on it.
post #4 of 7 Old 05-06-2013, 06:29 AM
Quoted: 890 Post(s)
Feedback Score: 3 reviews
Sounds like your ford dealer sucks and are just throwing parts at it. Go somewhere else who knows about the 7.3L. Lack of boost is pretty easy to trace down. Do you even have a boost gauge?
Corey@CNCFAB is offline
post #5 of 7 Old 05-06-2013, 07:00 AM Thread Starter
No boost gage but they have hooked one up and drove it showed boost and when it was lost
post #6 of 7 Old 05-06-2013, 09:33 AM
Justin@DP-Tuner's Avatar
Quoted: 66 Post(s)
There are only a handful of places you will leak boost or drive pressure. Pressurize the intake system and spray soapy water on all connections. Look for soot on the up-pipes as well.
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
post #7 of 7 Old 05-06-2013, 07:12 PM
Quoted: 890 Post(s)
Get yourself a piece of PVC pipe and reducers to hook up an air hose. Then pull your main intake hose off after the filter and put about 40 psi to it (turn your air compressor regulator down to 40psi to do this). Shouldnt need any more than that.
